mrbietola
Multi controller MIG clock topology
Hi, i have 2 DDR3 controllers in one MIG instance.
Every controller puts out a  c*_ui_clk.   Microblaze Data Cache is connected to an axi interconnect and "sees" both controllers. It's clocked by c0_ui_clk.
Are the accesses to controller 1 still synchronous?
If i add a VDMA that writes to controller 1, should it be clocked by c1_ui_clk?    If i use c0_ui_clk instead, the interconnect manage the clock conversion?
It's better to clock all the peripherals to only c0_ui_clk (design is easier to implement)?   What about a VDMA that accesses both controllers?
vsrunga
@mrbietola
Even though they are of same frequency(same meory clock and phy to controller ratio)  they are genarted using difefrent MMCMs
We recommend you to use respective ui_clk for the AXI interconnect.
-Vanitha
mrbietola
Thank you for your reply, but i'm not sure i understand, can you formulate a connection example?
For example 2 VDMAs, each connected to a different controller...
Should i use 2 interconnects, each interconnect clocked by C*_ui_clk (ACLK pin),  each VDMA clocked by C*_ui_clk?
mrbietola
If i try to do 2 interconnect and run automation, Vivado still to use C0_ui_clk for both interconnects. If the c*_ui_clk are asynchronous, why Vivado try to connect to an asynch clock?
