Need IBIS MODEL for XCZU9CG-2FFVC900I on urgent basis
I need IBIS MODEL for the XCZU9CG-2FFVC900I  for this model on urgent basis.Please revert back ASAP.
Re: Need IBIS MODEL for XCZU9CG-2FFVC900I on urgent basis
Vivado can generate IBIS models
Hi rekha.bhagat@aricent.com
Vivado provides IBIS model.
Open implemented design of FPGA you are looking.
Go to File and Export IBIS model.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Alternatively, you can start an I/O Planning Project where you will not have any HDL but can configure your I/Os and generate the IBIS model
That's good for keeping the hardware guys happy, busy and away
