patmcn
PS DDR register errors next step?
Hi, I'm trying to debug my DDR4 on a custom board.  The common error I found on the forums that was similar to mine was the psu_init.tcl script hanging with no UART output.  I was able to get the PMU and FSBL loaded successfully and have been probing the DDR PHY status registers but I need help knowing what the next step should be.
My DDR PHY (0xfd080030) returns (80C000FF <Hex Integer>).
I'm not sure what the difference between hex integer and hex is supposed to mean but I assumed it is supposed to be 0x80C000FF which would mean that my DDR is getting a DQS Gate Training Error and a Write Leveling Error.
Using SDK 2018.3, zcu2eg, custom board with ddr4 (MT40A512M16LY-062E IT:E) and I attached my ddr settings from vivado.
Any suggestions? Thanks!
watari
Hi @patmcn
As you know, DRAM controller for DDR3/DDR4 has write leveling and read leveling function to adjust flight time (time distance).
"Write leveling" adjusts skew (phase) between CK and DQS.
However, dram controller has a capability (limitation) of this skew. It depends on length between CK and DQS, clock frequency and capability of controller.
So, I mentioned before as question.
Hope it helps.
Best regards,
watari
Hi @patmcn
Did you make sure your DDR4 pattern on PCB ? Especially, relationship between CK and DQS ?
Also, did you read PCB guideline for DDR4, too ?
If no, would you try them first ?
Best regards,
patmcn
I will double check those but yeah, I made sure to follow the ddr routing guidelines.
patmcn
patmcn
This was also helpful to find to slow down the ddr.  Posting link for future refernce.  Checking if it might help my design now.
https://forums.xilinx.com/t5/Processor-System-Design-and-AXI/Zynq-Ultrascale-PS-DDR-EDAC-errors-when-accessing-memory/td-p/856878
patmcn
This link was very useful in breaking down all of the DDR parameters I wish was clearer with Xilinx documentation:
https://www.element14.com/community/groups/fpga-group/blog/2018/07/31/lpddr4-timing-parameters-for-zynq-ultrascale-mpsoc-in-vivado
patmcn
patmcn
I've been able to get my 0xFD080030 register to read out 0x80000FFF.  That would indicate that the DDR4 has initialized correctly, right?
I was able to adjust multiple ddr settings between using the ddr-1600 and ddr-2400 by taking the default clock (800MHz and 1200MHz, respectively) and reducing the clock speed 200 MHz for each.  Now I can at least see that the FSBL is not hanging and I'm getting info out of the UART.
Since I was able to see it configure by reducing both configurations clock speed, that would seem to indicate to me that I have a CK length issue.  Anyone have any thoughts? @watari maybe this is what you were getting at?
watari
Hi @patmcn
Hope it helps.
Best regards,
