Visitor gaoyuzhe
Problem with simulation of DDR3 Model in vivado
I can run the Example design of MIG 7 series successful, and the TCL console output should be like this:
# source -notrace {../../../../imports/xsim_options.tcl}
sim_tb_top.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2
sim_tb_top.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 Partial Array Self Refresh = Bank 0-7
sim_tb_top.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 CAS Write Latency = 8
sim_tb_top.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 Auto Self Refresh = Disabled
sim_tb_top.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 Self Refresh Temperature = Normal
sim_tb_top.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 Dynamic ODT = Disabled
sim_tb_top.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2
sim_tb_top.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 Partial Array Self Refresh = Bank 0-7
sim_tb_top.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 CAS Write Latency = 8
sim_tb_top.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 Auto Self Refresh = Disabled
sim_tb_top.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 Self Refresh Temperature = Normal
sim_tb_top.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 1220189.0 ps INFO: Load Mode 2 Dynamic ODT = Disabled
sim_tb_top.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 1870189.0 ps INFO: Load Mode 3
sim_tb_top.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 1870189.0 ps INFO: Load Mode 3 MultiPurpose Register Select = Pre-defined pattern
sim_tb_top.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 1870189.0 ps INFO: Load Mode 3 MultiPurpose Register Enable = Disabled
sim_tb_top.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 1870189.0 ps INFO: Load Mode 3
sim_tb_top.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 1870189.0 ps INFO: Load Mode 3 MultiPurpose Register Select = Pre-defined pattern
sim_tb_top.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 1870189.0 ps INFO: Load Mode 3 MultiPurpose Register Enable = Disabled
run: Time (s): cpu = 00:00:03 ; elapsed = 00:00:09 . Memory (MB): peak = 865.727 ; gain = 0.000
xsim: Time (s): cpu = 00:00:14 ; elapsed = 00:00:17 . Memory (MB): peak = 865.727 ; gain = 70.527
INFO: [USF-XSim-96] XSim completed. Design snapshot 'sim_tb_top_behav' loaded.
INFO: [USF-XSim-97] XSim simulation ran for 1000ns
launch_simulation: Time (s): cpu = 00:00:17 ; elapsed = 00:00:26 . Memory (MB): peak = 865.727 ; gain = 88.891
But when I use the ddr3_model.sv and ddr3_model_parameters.vh,  MIG IP core   and my own model to generate signals for user interface. When I run the simulation, the TCL console output is like this. Before the message of load mode appera, I think the outputs are same.
ddr3_tb.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 601017689.0 ps INFO: Load Mode Z
ddr3_tb.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 601017689.0 ps INFO: Load Mode Z
ddr3_tb.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 601667689.0 ps INFO: Load Mode Z
ddr3_tb.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 601667689.0 ps INFO: Load Mode Z
ddr3_tb.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 602317689.0 ps INFO: Load Mode Z
ddr3_tb.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 602317689.0 ps INFO: Load Mode Z
ddr3_tb.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 602967689.0 ps INFO: Load Mode Z
ddr3_tb.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 602967689.0 ps INFO: Load Mode Z
ddr3_tb.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 603617689.0 ps INFO: ZQ        long = z
ddr3_tb.mem_rnk[0].mem.gen_mem[1].u_comp_ddr3.cmd_task: at time 603617689.0 ps INFO: ZQ        long = z
PHY_INIT: Memory Initialization completed at 604855100.0 ps
ddr3_tb.mem_rnk[0].mem.gen_mem[0].u_comp_ddr3.cmd_task: at time 604907689.0 ps ERROR: Activate  Failure.  Initialization sequence is not complete.
I really don't know why Load Mode is constant Z. I think I have connect the dd3_model and mig ip core. Can anyone told the reason?
回复: Problem with simulation of DDR3 Model in vivado
It seems the DDR3 model is not properly initialized. Did you check the difference on the connection/parameters with DDR3 model?
Visitor gaoyuzhe
I finally find the resolution. Adding the wire delay in the inout port will solve the problem. But I also find an example, which not using wire delay model. I compare the difference between the two examples and find the ddr3_model.sv and its parameter file is almosts same. The only difference is the define device type. I use two banks and the example without wire delay model uses one bank.
So I am still confused with the reason.  Any help will be appreciated.
The wire delay model is attached. I think it is only a three-state buffer.
Observer choksiv
Hi @gaoyuzhe ,
I guess I am having similar issue as you. Can you elaborate more in detail about how you resolved the issue? As part of my MIG, the dqs_n and dqs_p signals are 8-bit wide but for ddr3, they are declared 2-bit wide only. Why is it like that? How to resolve such issues?
Also, I have added the wiredelay file already but still I am getting the same error. Something like below:
Testbench.mem_rnk[0].gen_mem[6].ddr3_model.cmd_task: at time 6032210.0 ps INFO: Load Mode Z
Testbench.mem_rnk[0].gen_mem[7].ddr3_model.cmd_task: at time 6032210.0 ps INFO: Load Mode Z
Testbench.mem_rnk[0].gen_mem[0].ddr3_model.cmd_task: at time 7332210.0 ps INFO: ZQ long = z
Testbench.mem_rnk[0].gen_mem[1].ddr3_model.cmd_task: at time 7332210.0 ps INFO: ZQ long = z
Testbench.mem_rnk[0].gen_mem[2].ddr3_model.cmd_task: at time 7332210.0 ps INFO: ZQ long = z
Testbench.mem_rnk[0].gen_mem[3].ddr3_model.cmd_task: at time 7332210.0 ps INFO: ZQ long = z
Testbench.mem_rnk[0].gen_mem[4].ddr3_model.cmd_task: at time 7332210.0 ps INFO: ZQ long = z
Testbench.mem_rnk[0].gen_mem[5].ddr3_model.cmd_task: at time 7332210.0 ps INFO: ZQ long = z
Testbench.mem_rnk[0].gen_mem[6].ddr3_model.cmd_task: at time 7332210.0 ps INFO: ZQ long = z
Testbench.mem_rnk[0].gen_mem[7].ddr3_model.cmd_task: at time 7332210.0 ps INFO: ZQ long = z
PHY_INIT: Memory Initialization completed at 9805100.0 ps
Testbench.mem_rnk[0].gen_mem[0].ddr3_model.cmd_task: at time 9912210.0 ps ERROR: Activate Failure. Initialization sequence is not complete.
Can you please help on this? I have been stuck on this for quite some time now. Any help is much appreciated.
One more thing, did you check the simulation language option (tools-> settings) is set to mixed?
Observer choksiv
Yes @kren it is set to mixed language only. I believe that is not causing the trouble. Please help on this. This is really urgent.
Regards..
Visitor gaoyuzhe
Do you use generate command to instantiate ddr3_model?
Observer choksiv
Hi @gaoyuzhe ,
Thanks for responding. Yes, I am using generate command to do so. Is there anything I should do differently?
Looking forward.
Regards..
Visitor gaoyuzhe
So you use more than one bank. You are supposed to instantiate four ddr3_models. You can read the eample project code and imitate how to instantiate ddr3_model in its top verilog file.
