QDRII+ SRAM and MIG Interface
There are some questions about the MIG and QDRII+ implementation;
  1. This memory part (CY7C2663KV18 - 450BZI) has a 2.5 Cycles read latency. Should I state this latency in the configuration of MIG IP? And for this purpose, which parameter do I set in MIG GUI?
  2. How should I decide that which IO banks will be used for this QDRII+ SRAM ? HP or HR banks? Could we use the HR banks for QDRII+ interface where QDRII+ SRAM works at the 300MHz ? What is the max frequency limit for HR banks?
  3. This part has an input that is DOFF( PLL turn-off(active low)). MIG generated an output port that is qdriip_dll_off_n. I think that these two pins will be needed connect to each other. Right?
  4. This SRAM is ODT cabaple. D[17:0], BWS[1:0] and K inputs should be on-die terminated. ODT resistor is calculated by another pin ZQ which is tied to GND by an RQ resistor. ODT resistor is determined by using the this RQ resistor. This RQ value is directly proportional to Xilinx HSTL buffer output impedance. How can we find the HSTL buffer output impedance  ?
  5. MIG does not generate QVLD pin. It will be terminated according to the this  question in forum, right?( https://forums.xilinx.com/t5/Welcome-Join/QDR-connection-with-Virtex-7-XC7VX485T/td-p/746211)
  6. I am confused a bit about the following connections between MIG and QDRII+ SRAM are correct or not ?
MIG pin                  QDRII+ SRAM pin
qdriip_w_n --> WPS (write port select)
qdriip_r_n --> RPS ( read port select)
qdriip_bw_n[1:0] --> BWS[1:0] ( byte write select)
Thank you very much,
Tags (4)
Re: QDRII+ SRAM and MIG Interface
Hello @doner_t,
All of the information you requested is available in the following User Guides and Data Sheets:
https://www.xilinx.com/support/documentation/ip_documentation/mig_7series/v4_2/ug586_7Series_MIS.pd
https://www.xilinx.com/support/documentation/data_sheets/ds187-XC7Z010-XC7Z020-Data-Sheet.pdf
https://www.xilinx.com/support/documentation/data_sheets/ds191-XC7Z030-XC7Z045-data-sheet.pdf
Please look through this documentation and your vendor data sheet and if you still have questions, then let us know.
Cory
