lizcorrigan
Re: Can't generate DDR3 for xc7a35t
Im having the same problem, trying to create DDR3 using MIG for xc7a35t.  Im using Vivado 214.3 with MIG version 2.2.  So it looks like this issue still hasn't been resolved.
Will also have the same issue with the work around, as we are also using a small package, so no functional pin compatible option.
Please can I get an update.  Does xc7a35t support DDR3 interface?  is it possible to use MIG to generate a controller core?
lizcorrigan
Hiya,
This still doesnt help me generate the IP for CPG236 package, but I think we have found a way to work around this in 2014.3.
Liz
vsrunga
@lizcorrigan
Vivado 2013.4 MIG do not generate the IP for CPG236 package alone! If you are targetting the same package please viist below link for workaround
http://www.xilinx.com/support/answers/59632.html
lizcorrigan
Hiya,
Liz
