taganrog
Re: MIG User Interface back-to-back Write Timing
HI!
PG150 at page 83:
"As shown in Figure 4-2, page 81, the maximum delay for a single write between the write data and the associated write command is TWO clock cycles. When issuing back-to-back write commands, there is NO maximum delay between the write data and the associated back-to-back write command, as shown in Figure 4-5."
Why the difference between back-to-back and single commands? Model with back-to-back write commands and one clock cycle delay for write data works properly.
vsrunga
As it is back to back, I assume you are referring delay of 2 clocks for first write command versus data, if yes you can have it but for the subsequent commands app_wdf_data will follow previous data without out any gaps
Also visit below links for relavant discussions
http://forums.xilinx.com/t5/MIG-Memory-Interface-G​enerator/can-there-be-1-or-2-empty-cycle-delay-bet​ween-two-halves-of-BL8/m-p/364047#M4380
http://forums.xilinx.com/t5/MIG-Memory-Interface-Generator/Mig-User-Interface-Back-To-Back-Timing/td-p/503861
http://forums.xilinx.com/t5/MIG-Memory-Interface-G​enerator/MIG-DDR3-questions-about-delays-and-buffe​rs-depthes/td-p/272216
-Vanitha
vsrunga
In back to back command mode it is asumed that data is avaiable in the FIFO and hence the delay is not a big restriction.
For single write command you should make sure that the data associated with that specific address is supplied with in the time else existing data in the FIFO might be sent and there are chances to see misalignment
In any case you should be careful that data is sent first and then the command.
Note that controller will not validate which data belongs to which address and hence you need to take care that required data goes along with specified address
Hope this helps
-Vanitha
taganrog
Thank you. I will ask otherwise. PG150 (november 19, 2014) at page 87 for non back-to-back write command:
"Write data is presented AFTER the corresponding write command, but should not exceed the limitation of TWO clock cycles."
Can I use this rule for the back-to-back write command?
vsrunga
-Vanitha
