z9p
Re: MIG module for Gensys board
Did anybody figure out the exact parameters to put into the MIG?  I am facing exactly the same problem, trying to utilize the DDR2 on a Genesys V5 board.  I have the right pinout .ucf but I couldn't find any information concerning the correct parameters for MIG.
vsrunga
@z9p  P.S:-  If your current question is similar to old posts for reference you may give the old link, but always consider to start your questions in new threads instead of posting in some one's old threads.
If you found a base part that matches with your actual part timing paranters that have to be modified will be given in MIG Custom part GUI
Here is the snapshot for reference, You can find more info on the same under help menu
Hope this helps
Vanitha
