taganrog
Re: System Clock, PLL Location, and Constraints
Can sysclock come from CCIO that locate in the same column, but not in the adjacent (or the same) bank?
vsrunga
@taganrog please always start new threads for your new questions.
From UG586 -
The system clock input must be in the same column as the memory interface. The system clock input is recommended to be in the address/control bank, when possible
So Sys clock can come from any bank wih in the same column, if in case you see implementation errors you can use CLOCK DEDICATED ROUTE constraint, refer below link for more details
http://www.xilinx.com/support/answers/40603.html
Hope this helps
-Vanitha.
vsrunga
From UG586 -
Hope this helps
-Vanitha.
