Reagarding QDRIISRAM user application
I am using QDRIISRAM (MIG) with virtex7.
I need to implement Bulk of data write and read from memory.Where i can  modify in example design ?
Sunitha
Re: Reagarding QDRIISRAM user application
You need to replace the traffic generator with your own module to write and read through the user interface.
The timing diagrams and details of user interface can be found in below doc
http://www.xilinx.com/support/documentation/ip_documentation/ug586_7Series_MIS.pdf
Satish
Satish
   Thanks for your reply. Problem is solved ,i have written my own logic instead of Example design.
Sunitha
