AlexProulx
Remove I/O BUF from MIG IP
Good Day,
I need to multiplex the signals coming out of the 7 Series MIG IP within the FPGA. However, as the IP is designed with integrated I/O BUF's, I am unable to place circuitry between the FPGA's I/Os and the MIG IP.
Is there anyway to bypass or remove those I/O BUF's? I am trying to avoid designing my own DDR controller from scratch to perform the task.
Options I am considering are as follows:
  1. Removing the I/O BUF from the IP in block design.
  2. Feeding the Output buffer to the Input buffer on the same IO BUFF in order to  re-insert the signal into the FPGA. However, even if possible, I believe this would create an issue for bi-directional signals such as DQS and DQ.
  3. Directly manipulating the netlist to remove I/O BUF. Not sure how this would work.
Thank you,
Alex
Tags (4)
rpr
IP configuration doesn't provides bypass or remove those I/O BUF's.
MIG source code is not encrypted, generate the IP output products in global and modify the source code as per your requirement.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
