10-23-2020 07:05 AM
Good Day,
I need to multiplex the signals coming out of the 7 Series MIG IP within the FPGA. However, as the IP is designed with integrated I/O BUF's, I am unable to place circuitry between the FPGA's I/Os and the MIG IP.
Is there anyway to bypass or remove those I/O BUF's? I am trying to avoid designing my own DDR controller from scratch to perform the task.
Options I am considering are as follows:
Thank you,
Alex
10-26-2020 11:00 PM
IP configuration doesn't provides bypass or remove those I/O BUF's.
MIG source code is not encrypted, generate the IP output products in global and modify the source code as per your requirement.
