kaisrmaulo5
So I have a question concerning memory interface width.
When is the memory interface width of a GPU important? What exactly is it? How is it related to the memory bandwidth of a GPU? I'm asking because I've actually never thought about this when buying a GPU.
calibra
memory bandwidth  = Frequency * memory interface width
Fundamental when the operation number is similar to the number of data used.
Example vector multiplication.
Less important as the number of operations is much higher than the number of data used.
Example matrix multiplication.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
kshimizu
Hello @calibra ,
The Maximum frequency is depend on the FPGA device and DDR memory, so please check with AC-DC characteristic datasheet.
The Bandwidth is changed by the addressing since UltaScale Memory controller use the Group FSM to access efficiency.  Table 2-1 shows some patterns.
https://www.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_4/pg150-ultrascale-memory-ip.pdf
An example design create a simulation model, so please try to evaluate the bandwidth based on your addressing.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
calibra
@kshimizu
I do not understand your answer, I have only answered a generic question about the bandwidth on GPU.
