dare_bandom
To work around the clock cycle delay by fsm to prevent timing issue
I have an input to my module,'ready' signal(app_rdy_1) which goes low at random time for some short duration & then goes back high.
When the ready signal goes low,i need to maintain the values of some of my signals.
I will explain for 1 signal.
1 of i/p to my module = count1(26 downto 0)
1 of o/p of my module = ui_c0_app_addr(26 downto 0)
The i/p to my module,count1 is coming from a counter.I stop the counter from incrementing when ready goes low.So obviously,the i/p to my module also stops incrementing when ready goes low.This can be seen in attached waveform.
In my module,through a fsm,i assign the count1 i/p to my o/p ui_c0_app_addr.So this gets delayed by 1 clock cycle.So when ready is low,my o/p changes once.How can i resolve this ?
Attached is a snapshot to understand it better.
andrewlan
I would say either...
1) Don't register your counter in stm.. or...
2) Add a register delay to the ready signal to align it with counter and use this as your ready signal
