mt-user-2019
True dual port PS-BRAM-PL with different ratio
Hello everyone,
My question concern True dual port Bram with different ratio with same clock .
PS <-> BRAM Port A
PS will access the port A with 32 bits width.
I was thinking to use Axi bram ctrl  and manualy link addr, clk, wrdata ...
PL <-> BRAM Port B
PS will access the port B with 16 bits width.
What I think IS correct :
To address a 32bits memory width I have to increment the address by 4. Address_0  : 0  /  Address_1  : 4 / Address_2  : 8  /  Address_3  : 12  / Address_4  : 16 ...
To address a 16 bits memory width I have to increment the address by 2. Address_0  : 0  /  Address_1  : 2 / Address_2  : 4  /  Address_3  : 6  / Address_4  : 8 ...
A memory (width  x depth)  32 x 1024 means that I have 256 words of 32 bits available.
There is no possible way to have a true dual port bram using 'Bram controller' mode  with different width on Port A and port B.
If I use Ps <-> axi_bram <-> Bram (bram controller mode with 32 bits width) I can not add some logic to modify the address that PS is using.
Thanks in advance if you see something that can Help me.
MT
mt-user-2019
is those 2 pictures are equivalent (behavior and performances) ?
1) link using the 'port'
2) link using signals
Again thanks in advance
M
REPLY to myself : You can mixte (1) and (2), it seems to work
MT
mt-user-2019
On vivado, for a BRAM
read width : ... bits
read Depth : ... words with the length of the width
Mem Size : ...  bytes (8 bits)
ex :
Width : 64 bits
Depth : 1024 'lines' of 64 bits each
So you can do  ( 64 bits  * 1024 words ) /8 = 8192 bytes
MT
mt-user-2019
I did not succed to use Bram with different ratio (port A 32biits width and port B 16 bits width)  SO I use the Write enable BUS on port B ..
MT
