joancab
Ultrascale Memory Bank/ Byte Planner
When using the mentioned tool, what are the rules to assign signals within each byte? Can they be swapped just respecting the differential pairs or are there any other restrictions?
kshimizu
Hello @joancab ,
Please refer to the PG150, especially PCB Guidelines for DDR_x.  As for the DDR4, it mentions from page.104.
https://www.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_4/pg150-ultrascale-memory-ip.pdf
UG583 says the Guideline for Memory Interface in Chapter 2, page.50.
https://www.xilinx.com/support/documentation/user_guides/ug583-ultrascale-pcb-design.pdf
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
kshimizu
Hello @joancab ,
Best regards,
Kshimizu
joancab
In my case is DDR3, so page 91 onwards in pG150
