j_kojima
Ultrascale & Vivado2014 schedule
Hi !
I'm planning measurement of LPDDR3 performance.
So, I'd like to confirm when can I get Ultrasclale Device & Vivado-2014.1 tools.
I think at least Vivado-2014.1 will release untill 2014.March. Is this correct?
Please let me know about these schedule.
j_kojima
yenigal
Vivado 2014.1 is scheduled for customer release in April 2014.
Satish
yenigal
Satish
hj
2014.1 will be released in April.
Harry
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
j_kojima
Hi  yenigal !
Thanks quickly replying.
I understood about Vivado2014.1.
How about Ultrascale device?
j_kojima
vsrunga
Ultrascale devices are being shipped to few customers but please contact your local FAE for more details.
However LPDDR3 is not yet included in Ultrascale MIG, there is a road map for 214.2/.3 and is subjective to change.
Hope this helps
Vanitha
yenigal
The ultrascale low end Virtex and kintex are being delivered from december and there are scheduled Early acess and few more high end devices being supported from April 2014.
I would suggest contacting your Local FAE for the device selection and it's availability.
Satish
j_kojima
Hi ! Vanitha
Thanks for replying.
I hope I could test LPDDR3 asap.
j_kojima
hj
Hi ,
Vivado 2014.1 has been released & you can download it from the following location http://www.xilinx.com/support/download/index.htm
Harry
