joancab
Ultrascale+ memory interface for LPDDR3
Will the DDR3 SDRAM (MIG) work for LPDDR3 memories?
In the GUI there are only MT41 parts, I'm targeting MT52.
kshimizu
Hello @joancab ,
UltraScale supports the LPDDR3 which PG150 mentions.
https://www.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_3/pg150-ultrascale-memory-ip.pdf
It there is no memory parts in the MIG GUI, please use the CSV in the AR#63462.
https://www.xilinx.com/support/answers/63462.html
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
joancab
Mmm, there is an LPDDR3 MIG that is not supported in IP integrator, it looks like I should use that.
kshimizu
Hello @joancab ,
Kshimizu
