serm_wang
VCCAUX_IO for Kintex-7
To whom it may concern,
I am using the XC7K160T FFG676, I am using bank 32, 33 and 34 for DDR3 SDRAM (1.5V) and planning to operate at 1.8Gbps.  I have following question.
1. Should I connect VCCAUX_IO_G (P8, R9 and T8)  to 1.8V?
2. Should I apply 2.0V on VCCAUX_IO_G (P8, R9 and T8) to achieve higher frequency performance?
3. Does VCCAUX_IO_G (P8, R9 and T8) are connected internally? Which mean the voltage of I/O circuitry of bank 32, 33 and 34 are going to be the same?
drjohnsmith
2) If you go outside the voltage spec, your on your own.
josephprodigy
you have to give supply from external.
Use 1.8V supply.
Check you are using DDR3L or DDR3 memory chip based on - same use 1.35V or 1.5V as Bank Supply for 34,35.
Please refer a schematics of spartan 7.
Please read UG586 pages - 102.
If possible use pinout through VIVADO - explained in UG586.
