polyee13
VCU118 DDR4 Single only?
Is it possible to only use a single DDR4 on the VCU118 or must both DDR4's (c1, c2) be used, hence two MIGs?
Tags (3)
rpr
Hi @polyee13
Yes, it is possible to use a single DDR4 on vcuu118. Configure the MIG core based on your requirement.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
rpr
Hi @polyee13
Pratap
