kencrocker
Vivado 2014.4 MIG7v2.3 DDR3 simulation Odd Behaviour
I am using the MIG generated sim.do script with modelsim to simulate the MIG example design.
As part of DDR3 initialisation, MIG seems to be issuing activate bank 0 row 0 followed by lots of read commands with undefined bank, col, and address (see attachment). The DDR3 model is not surprisingly returning undefined DQ.
Is this intentional behaviour as a bank and row have been opened?
It is causing problems with our DDR3 simulation model.
Ken
kencrocker
This is the equivalent capture using Vivado 2014.2 MIG2.1
vsrunga
Even after initialization MIG takes about 50 us to complete calibration, please run the simulation for some more time and check for init_calib_complete signal and then you can start your write /read interface.
If you do not see after calibration then please get back.
You can refer UG586 for more details.
Also please make a note that MIG simulation is supported only with IP generated model, other models may/may not work and needs testbench modifications which are out of scope of support
Hope this helps
-Vanitha
kencrocker
Hi Vanitha,
The design I am simulating works in hardware.
The MIG example design also passes simulation.
If I 'hack' our DDR3 model to accept READ commands with undefined address/bank, then my simulation passes.
My proposition is that I should not need to 'hack' my DDR3 model as MIG v2.1 initialisation exhibited reasonable behaviour by executing READ commands with defined address/bank, and MIG v2.3 is deficient in this regard.
Ken
