paradiselost
Whether One 7series FPGA MIG can support 16GB Memory.
ashishd
Please check the AR45195(link below), to find the list of memory devices supported
http://www.xilinx.com/support/answers/45195.html
Ashish
vsrunga
If you are using Vivado please refer below link for Supported memory parts.
http://www.xilinx.com/support/answers/54025.htm
More or less the same parts are supported in ISE as well.
I am not exactly sure of your memory part number and vendor details.
1GB is anyways supported but if your memory part is no tlisted in the drop down of MIG select a base part closest to your actual memory device go to custom part and change the parameters applicable
Please go through UG586 for more details
Hope this helps
Vanitha
ashishd
Ashish
paradiselost
thank you!
paradiselost
thanks!Your answer is very useful to me!
