Write to and Read from a DDR3 memory using the KC705 evaluation board
Hi, I am new in the FPGA area. I want to Write and Read data between the FPGA of the kc705 board and the DDR3 memory. I've been reading some documents related to a Memory Controller but I found that they are very large and complex to understand. Would you help with some documents or advises that had helped you making a task like I've just mentioned?
thanks
Hi @jose09621
Would you refer the following URL ?
https://www.xilinx.com/support/documentation/ip_documentation/mig_7series/v4_2/ug586_7Series_MIS.pdf
Also, I recommend to use MIG IP to access DDRx SDRAM. MIG is (DRAM) memory controller and you can access DRAM via AXI4 interface and so on.
Best regards,
You can start with the DDR3 example design for KC705 at: https://www.xilinx.com/products/boards-and-kits/ek-k7-kc705-g.html#documentation.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
Thanks, I'll see your links, and hope to reach the goal with this project.
