raymond715
[ZCU102 + HLS] Loss data when custom IP write to PL DDR4 by MIG
Hi, I'm beginner to fpga. I try to write data to PL DDR4 by MIG. In my block design, I add PS, my custom IP, MIG (DDR4) and other IP which is automatically generate by vivado. Details shown below.
In my test, PS send 512 unsigned int to custom IP (float data, 0 ~ 512, transfer as unsigned int, so for the correct data transfer, first data should be 0x0000_0000 and second should be 0x3f80_0000 however the first data I get in SDK is 0x4180_0000 which is 16 in float form). Custom IP write data to DDR4 by a m_axi port, and then read data from DDR4 by the same port (test if I have set MIG correctly). Then custom IP transfer data to PS.
The problem is I loss first 16 unsigned int when I read data by MIG (DDR4) and I cannot find reason. I am not sure if I have write first 16 unsigned int to DDR4 successfully. I mapped m_axi port to 0x8000_0000 and in my HLS src, array index start at 16, because I guess that maybe DDR4 cannot use first 512 bits correctly (obviously it is not the reason or I won't post problem here T_T). HLS src shown below.
I have tried to use ILA and waveform I get shown below. It is weird that it seems that first 16 data have been written to DDR4 as interconnect_write.wcfg shown and address is correct which is 0x8000_0040, but when custom IP (TestTransfer) try to read from DDR4, what it get from address 0x8000_0040 is 0x4180_0000, as testtransfer_read.wcfg shown. It is also weird that as testtransfer_write.wcfg shown, custom IP (TestTransfer) write first data to address 0x8000_0080. I don't know why it write to 0x8000_0080 first.
wf_axi_interconnect_read.pngwf_axi_interconnect_write.pngwf_testtransfer_read.pngwf_testtransfer_write.png
Any suggestions? I am not good at English and I hope I have stated my problem clearly. Thanks for your time!
raymond715
Well, I think I solved the problem of data loss. It seems that I didn't add TLAST signal in input_stream port in custom IP. I can get all data now, but I am facing a new weird problem. I will open a new branch for this T_T.
raymond715
Well, I found that if I add TLAST port in my custom IP, I won't loss first 16 data. But, now, I will get one wrong data after I get three correct data. Still don't know why...
raymond715
Data read from DDR4 is wrong. Still don't know why
raymond715
