ZCU104 SODIMM
Trying to change PL DDR4 controller to work with SODIMM we got (also Micron but 8GB), but pretty much all options in MIG are "greyed out".
So 4GB Micron is the only part supported out of the box right now? Or am I missing something?
Mentor
Mentor
I was able to select the MTA18ASF1G72HZ-2G3 in MIG using Vivado 2018.1 after setting the design target to the ZCU104.  The smallest clock cycle is only 938 ps, though.    See below:
Mentor
Mentor
