Pmn
Zynq, Access PS DDR
Hello all,
I am almost beginner with Zynq (I am using zcu102).
I have a basic question.
I used DMA and created a custom IP to write some data  from PL into the PS DDR (through HPC port).
Now I simply want to read the data already written into the PS DDR through the processor and send it back to PC using UART.
But I do not know how I can read data from PS DDR.
Is there any way that the processor can access DDR directly (only by addressing)?
If not, what is the standard way?
Could some one please  let me know what  the standard way of accessing PS DDR through the processor is?
Thakn you in avance
Nikhil_Thapa
@Pmn ,
1. Do you have any suggestion how I should test the data written into DDR?
reading DDR or other options such as ILA?
Yes, you can also use ILA. But, to read the DDR content particularly, use XSCT commands.
For example, if you want to read the memory content at location 0x81000000, then you will have to enter mrd 0x81000000.
For more other details, visit UG1208Chapter 3, Target Memory.
2. I wanted already to use Xil_In32 function to read memory. However, the problem was that I could not find the list of DDR addresses in Vitis (xparameters.c).
Do you know by chance which parameters listed in xparameters.c show addresses of DDR to be accessed?
No, you cannot find any list of addresses. If you looked carefully, you will get base address high address of PS DDR. Within these addresses, the data are actually read/written.
Now the thing is, you have to find the address value, you specified in the DMA configuration code in SDK/Vitis. Actually, that address is the beginning address from where DMA starts writing the data onwards.
Thanks and Regards,
Rmccarty
C? Use a pointer. You need to also take care of cache coherency as well. If the data size isn't too large you can use ocm instead of ddr or the acp port can write directly into the L2(?) Cache.
Nikhil_Thapa
Hi @Pmn ,
I firstly recommend you to check that the data is successfully written into DDR memory or not.
To read the DDR memory content from SDK/Vitis, you can use XSCT Console, where you have to enter the memory read command.
Yes.
You can use Xil_In32() function to directly read the data from the given memory location. You can also use memory function, like, memcpy(). To use this function, you have to care about Data Cache.
Thanks and Regards,
Pmn
Hi @Nikhil_Thapa
thank you very much for your help.
thank you
Pmn
Hi @Rmccarty
thank you for your answer,
  • could you please let me know what you mean from “take caring of cache coherency” And also pointer?
I did not get what you mean.
Rmccarty
How is the DMA working if you don't know the address?
Pointers are really basic C. I suggest you take a few steps back and learn some C as well as the basics of ARM core architecture.
Nikhil_Thapa
@Pmn ,
Thanks and Regards,
Pmn
Thank you very much @Nikhil_Thapa
Great!
It is very helpful
Nikhil_Thapa
Hi @Pmn ,
It's great hearing from you.
If you think your problem/issue is solved, you can close the thread by "Accept as Solution".
