ssampath
about DDR controller input clock(generated by MIG) ?
Hi Friends,
I have generated DDR3L memory controller and PHY using MIG. for this testing purpose i used on board differential clock as input to the controller.
But later can i use internal clock , like clock generated from MMCM or PLL . ?
Thank You
S Sampath
-Sampath
vemulad
Hi @ssampath
Yes, it is possible to use internally generated clock with 7 series MIG sys_clk input. However this is not recommended.
Deepika.
vemulad
Hi @ssampath
Deepika.
