simple.wang
axi-interconnect connect to MIG ddr3: simulation problem???(block design)
AXI interconnect (2 slave + 1 master) and  MIG  ddr3    simulation   pass    in IP catalog  ,
but  simulation   nopass by  block design .The  data input   AXI interconnect   but  cannot output to MIG ddr3,why?
I hope somebody can help me.
Thanks very much.
Simple
simple.wang
Hi Vanitha,
added addr offset in addr editor and chnaged areset,block design sim pass.
Simple
siktap
Hi Simple
Have your generated the outputs after validating your design?
Sikta
simple.wang
AXI interconnect (1slave + 1 master) and MIG ddr3 simulation pass in block design, why not pass 2 to1 interconnect ?
simple.wang
Hi Sikta,
Generate output products,but have critical Warnings :Address block <mig..../memaddr> is not mapped into a Mater Address space.
Simple
simple.wang
Hi Sikta,
1 to 1 AXI interconnect have the critical Warnings
Simple
simple.wang
Hi Sikta,
The data transfer to mmu but mmu ouputs wrong in vivado 14.3 .
The data teansfer to arbit but arbit outputs wrong in vivado 13.2.
Simple
vsrunga
By not passing you mean
Are you unable to write AXI interconect/AXI MIG is not ready ?  or
Able to write but the core is not responding for reads? or
Able to write and read but data do not match?
Please provide a block diagram description and elaborate the issue along with snapshots of relavant signals.
Do cross check if the connectivity and clock are proper, address mapping is correct.
-Vanitha
simple.wang
Hi Vanitha,
Simple
