mikerez
ck_p/n[1] absent for dual rank DDR3
After generating MIG2.3 in Vivado 2014.4 and 2015.3 I have cs_n[0] and cs_n[1], odt[0] and odt[1], cke[0] and cke[1]
but only one ck_p/n[0] in xdc.
Here you can see fly-by that needs two clocks: CK0 and CK1
https://www.micron.com/~/media/Documents/Products/Data%20Sheet/Modules/Unbuffered_DIMM/jtf16c256_512_1gx64az.pdf
Where should I get CK1?
Thank you.
vsrunga
@mikerez
The datasheet you referred is for DIMM, but you have slected component, please select memory type as UDIMM, choose dual rank part and recheck the xdc
vsrunga
@mikerez
What memory devie are you uisng?
Can you uplod your mig.prj, .xml and .xdc files to check at our end?
mikerez
vsrunga
@mikerez
mikerez
thank you, I missed this. This right.
