murali@1996
error[Common 17-37] while implementing DDR4 MIG in VIVADO2016.4
I was Tried to implement the DDR4 interface in the Kintex ultra scale with VIVADO2016.4 for the SDRAM(MT40A512M16HA-083E)
during the implementation the below error was came, Can any one help me to resolve the issue..?
  • [Common 17-37] Directory in which file u_mig_ddr3_phy_phy.xdc is to be written does not exist [C:/Users/itsadmin/AppData/Local/Temp/7264/project_1/u_ddr3_mem_intfc]
  • [Common 17-69] Command failed: ERROR: [Common 17-37] Directory in which file u_mig_ddr3_phy_phy.xdc is to be written does not exist [C:/Users/itsadmin/AppData/Local/Temp/7264/project_1/u_ddr3_mem_intfc]
regards
Murali
johnvivm
Voyager
Voyager
murali@1996
Check this: open Vivado (with no project open). Click Tools > Settings. Then 'Project' in the left panel. Check the default directory not to be a 'special' one restricted by the OS.
johnvivm
Voyager
Voyager
Strange it goes to AppData/Local/Temp to look for those files...
Have you created your project in a 'normal' place, like C:/projects or in your username folder?
Could it be you have your project in a user space (itsadmin) with admin rights and you are launching Vivado with another user without those superpowers?
murali@1996
Actually the Design folder and all the sources are in D:/folder/folder/... only...! not in C:/user/itsadmin/......,.
while running implementation a new temp folder is automatically created. in that folder it was expecting the .XDC file...
don't know why...
murali@1996
I have tried to RUN with admin rights. and tried with different PC's also. but the Same error is came again and again. then What will be the problem...?
johnvivm
Voyager
Voyager
There must be something wrong with the project settings... could you start a new project in another folder and copy all your sources and constraints?
murali@1996
Yes,
Actually I was created the new project only for DDR3/DDR4 and Compiled. there is no other files in that. even-though the Error remains...!
regards
Murali
johnvivm
Voyager
Voyager
murali@1996
murali@1996
yes, Thanks...!
.@.@.v.@.@.
I'm having the exact same issue; I don't see the chain of options that you suggested.
Can you provide screen shots?
yunleiz
how to do when using the terminal flow?
