sarlaga3
i'm now generating a zynq ultrascale+ mpsoc ip,can i use the default setting for the ddr option
QQ截图20210220161026.pngQQ截图20210220161047.pngi'm now generating a zynq ultrascale+ mpsoc ip.iand  have choose the board zcu102 for the project when building the project.now i come to step to configure the ddr option in the zynq ultrascale+ mpsoc,can i use the default setting for the ddr option or do i have to change the default setting for the ddr option?why there is 4GB ddr capability on the zcu102 board and there is only 2GB ddr capability in the default setting for the ddr option?
tamas.kiss
There are two types of SODIMM memories that shipped with ZCU102 boards. You can find the settings for your board here.
EDIT: Also, running the block automation after adding the MPSoC to your block design will configure the DDR for the old model.
kshimizu
Hello @sarlaga3 ,
If you use the ZCU102, you can use the default settings.  If you use custom PCB, please set the appropriate values in the GUI.
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
