problem with the netlist generation in edk which has mig interface
the target device is artix-7 and i am using xilinx ise14.7 version
vsrunga
@geethavaradaraju
Can you please elaboarate your problem with log files and snashots?
i have added the mig ip interfaced with the microblaze processor and trying to generate the netlist but i am getting error:3900 which MIG invoke error.....
vsrunga
@geethavaradaraju
Above the errors I see a message that  you have selected invalid time period, viist the IP GUI again and change the memory clock period in allaowed valid range and recheck
-Vanitha
i have set the edk to calculate the clk period and the frequency i have choosen is 400Mhz. here is the snapshot......
vsrunga
@geethavaradaraju
But 1250 is 800Mhz which does not match with your sleected 400Mhz, please check if external clock has a different frequency which can cause this behaviour.
external frequency is 100mhz out of which i am deriving 800Mhz with phase 337.5 for freq_refclk and mem_clk is 800Mhz which is 4*clk_ref.
vsrunga
@geethavaradaraju
Please generate 400Mhz and assign it mem_clk
You can refer table 1-61 for difefrent clock definitions
http://www.xilinx.com/support/documentation/ip_documentation/mig_7series/v2_4/ug586_7Series_MIS.pdf
even i tried that i am getting the following error which i have attached....
vsrunga
@geethavaradaraju
Can you upload your system here?
PFA
Thank u vanitha for your support, my issue is resolved....
vsrunga
@geethavaradaraju
It is basically the clocking. Glad that the issue is resolved.
Christian1
Hello, how did you resolve it?
