Visitor ted_130706
Can not keep timing of maximum clock skew inside the MIG
Timing of maximum clock skew of RIU_CLK of BITSLICE_CONTROL inside MIG can not be kept
- Vivado : Vivado 2017.4
- FPGA : KintexUltraScale
It is difficult, as it is clock skew.
What could be the cause?
The following answers have been checked.
AR# 68169 , 68266
 -- 2017.4 was not covered by TCL.
** First design created in 2016.2
https://www.xilinx.com/support/answers/68266.html
https://www.xilinx.com/support/answers/68169.html
AR# 68976
-- Do not use Pblock
https://japan.xilinx.com/support/answers/68976.html
Re: Can not keep timing of maximum clock skew inside the MIG
Hello @ted_130706,
The IP generated default constraints should be able to maintain the correct skews so if you design cannot then it's possible you have a user constraint that broke something in the IP generated default constraint, there's too much congestion in your design, or you have an invalid clocking topology.  I would first check for a user constraint to see if you generated an overly broad set_clock_groups -asynchronous -group [clocks].  Next I would try reducing the amount of logic in your design or try different implementation strategies. Also double check the clock sources in the MIG are correct, meaning a reference clock that's entering in the MIG I/O bank column and that there are no user changes that modify the LOCs for any of the MMCMs or PLLs used by the MIG.
Visitor ted_130706
Hello ryana ,
Thank you for your reply.
It was strange that skew will occur between BUFG and BITSLICE_CONTROL.(It is a CLK leased line.)
I got advice and confirmed the design.
Although the usage rate is not so high, clocks were supplied to other primitives within MIG's IP.
I will try separating the BITSLICE_CONTROL and other primitive clock buffers.
