Visitor syang
Custom MIG driver?
What are the proper steps to ensure the driver has been updated correctly for the custom IP?
I went to the .mdd file and added the name of my custom IP to "supported_peripherals". It seem to be picking up the driver on SDK, but it does not seem to be exporting all the hardware configurations over, and I'm not able to choose the DDR3 memory on the memory map.
Re: Custom MIG driver?
Hi- there are additional TCL files in the driver that are used to automate the creation of the memory ranges. You'll have to make sure your custom core exposes the same parameters.
Overall, I'd suggest just defining the memory ranges yourself in the linker file.
Hello @syang,
Is is this in relation to you AXI MIG migration question from a few days ago? I don’t quite understand what you are trying to do. Could you please elaborate?
Cory
Visitor syang
We certified a version of the MIG back in EDK, now we are providing certification for its compatibility in Vivado.
Hello @syang,
Please follow the steps outlined in your previous thread:
https://forums.xilinx.com/t5/Memory-Interfaces/Migrating-EDK-MIG-to-Vivado/m-p/847750#M11831
AND/OR
UG911 for AXI MIG Migration: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug911-vivado-migration.pdf#page=82
Cory
Visitor syang
Again, these are completely irrelevant.
Hi @syang
After building the hardware FPGA design in Vivado, did you use the Export Hardware function? That should create a BSP that you can import to SDK.
M
Visitor syang
Yea, I did. The base addresses was exported as part of the .hdf file. When I went create the memory test, the addresses does not get copied over, and I feel like the SDK is still not fully recognizing my custom IP.
Visitor syang
@mcertosi by the way, this may help clearing thing up. My custom IP has a different name. That's why I had to add it to the .mdd file. This was all I had to do back in EDK, and it worked.
Visitor syang
That makes sense. My custom core still has different parameters. Thanks!
