Observer driss
DDR3 Memory Port not be allocated
Hello!
I have a design with DDR3 SDRAM, using MIG v4.1 successfully with Vivado 2018.1 version.  After upgrading to MIG v4.2 with 2018.3 version, I get the error shown below when I try to validate the pinout.
Best regards,
Driss
Re: DDR3 Memory Port not be allocated
Hello @driss,
I was able to get development to "uprev" the patch in AR71898 to include a fix for your issue. I will send it to you directly through EZmove. I am working on getting the AR updated/pushed external again with the new documented issues/fixes.
https://www.xilinx.com/support/answers/71898.html - When pushed public again, will include AR71898_vivado_2018_3_preliminary_rev2.zip and no longer include AR71898_vivado_2018_3_preliminary_rev1.zip (as all of rev1 fixes are included in rev2.)
Please mark this post as a solution when you have verified your issue is resolved with the rev2 patch.
Cory
Hello @driss,
Do you run into this issue while using the patch provided in https://www.xilinx.com/support/answers/71898.html. We had some regressions in 2018.3 7-Series MIG that this patch should alleviate.
Cory
Observer driss
Hello @coryb,
I still get the issue using the AR71898 path provided.
Best regards,
Driss
Hello @driss,
Please provide your PRJ file inlcuding this pinout so I can look into the issue.
Cory
Observer driss
Hello @coryb,
I enclose the prj and xdc files.
Driss
Hello @driss,
Cory
Observer driss
Hello @coryb,
Thank you for the patch. The patch fix the issue.
Best regards,
Driss
