Participant mobileblue
DDR3 read problem
hi, folks:
We need to repeatedly read same data from ddr3 (sequential read, no write). A fifo is used to synchronize the app_rd_data to our user_rd_clk. We observed that: if we set the user_rd_clk to 120MHz, everything is fine; however if the user_rd_clk is set to lower frequencies, such as 24MHz, 36MHz, 48MHz, we can find sparse one or two-bit errors in the 256-bit app_rd_data. All timing constants are met.
Did anyone have the same experience? Any suggestions? Thanks a lot.
M.B
Teacher eteam00
Re: DDR3 read problem
Are you running the memory too slowly to permit required refresh?  Or are you varying only the user clock and not the memory clcok?
-- Bob Elkind
SIGNATURE:
Summary:
Did you check if the data FIFO is full?
Thanks for the reply.
memory clock is 400MHz. Yes, we only vaired the user clock. The memory clock is fixed.
The errors were caught at the fifo input. We also monitored the full signal. It was not full when the error occured.
One more thing. The problem occurs only when the full project is running. If only the ddr is running, there is no error.
Teacher eteam00
For Virtex-6 MIG-generated designs, varying the user clock (to the user interface port of the controller) is not supported.  From UG406 Table 1-18:
This UI clock must be half of the DRAM clock.
Are you targeting a Virtex-6 device?
Have you tried using the standard user clock (1/2 x memory clock) ?
-- Bob Elkind
SIGNATURE:
Summary:
The name I used might be misleading. For "user_rd_clock", I mean the fifo read clock. The MIG UI clock (also the fifo write clock) is fixed at 200MHz.
