Newbie dionhicks
DDR4 Mig User Interface Simulation
Hi!  I was wondering if it is possible to generate a DDR4 MIG example simluation design which utilizes the user interface instead of AXI4 in Vivado 2018.3?  I've been able to get the AXI4 example design working but I cannot figure out how to generate a user interface design.  Any help is appreciated.  Thanks in advance.
Re: DDR4 Mig User Interface Simulation
Hello @dionhicks,
1) If you are designing in IPI the AXI Interface for DDR4 is ALWAYS enabled and cannot be disabled.
2) If you build the DDR4 IP Example Design from within IPI, this will open up an RTL based Example Design with the AXI Interface ALWAYS enabled (as it carries over the ALWAYS enabled settings from IPI)
Please open up IP Catalog and Customize a DDR4 IP here. We give you the option to use just the User Interface OR the AXI Interface in this configuration. THEN build your IP Example Design and simulate. You should see a completely different traffic generator delivered.
Cory
Newbie dionhicks
Thanks for the reply!  I actually figured it out on my own after using the method you described. To get the simluation project created I just had to right click on the module that the IP catalog generated and open the IP example that way.
