DMA Principle
Accepted Solution Solved
Accepted Solution
DMA Principle
Hey Guys,
I am building a device for networking usage, where an AXI-ETHERNET IP is fed with data from DRAM through AXI-DMA.
AXI-ETHERNET works with AXI-STREAM and DRAM with the full AXI interface.
So let's say the ETHERNET -IP receives  1Mb of data, and I want it to be saved in the DRAM.
How does DMA know where to save that data? How do I know where the data goes (Address)?
Re: DMA Principle
then you can have a look at the examples provided by Xilinx. They are easily accessible at the BSP screen of the SDK ("Import Examples").
Screenshot
Reading the code you can learn more about how to use the DMA in different modes. When you call the functions to move the data, you indicate where it is located. For example (xaxidma_example_simple_poll.c):
Status = XAxiDma_SimpleTransfer(&AxiDma,(UINTPTR) RxBufferPtr,
					MAX_PKT_LEN, XAXIDMA_DEVICE_TO_DMA);
"RxBufferPt" is pointing to a memory address where the data must me stored. It was initialized previously in the code.
Ignacio
All Replies
Re: DMA Principle
are you using any processor in your design to configure the DMA (Zynq or Microblaze)?
Ignacio
Re: DMA Principle
Yes, I am using the ARM Core on the ZYNQ.
Re: DMA Principle
Screenshot
Ignacio
Re: DMA Principle
Thanks!
Re: DMA Principle
You're welcome!
Ignacio
