HBM actual bandwidth
Hi all,
I'm using HBM on VU37P FPGA. Just wonder that is there anyone out there using it too? Since I built a bandwidth testing block, the result is not so good as below:
Access pattern : {row,bank,col} : 40 % bandwidth
Access pattern:  {row,col,bank} : 60 % bandwidth
Access pattern: {row,col,bank}, Read write simultanously : 25 % bandwidth.
Is that because of technology limitation or my access pattern. Need advice.
回复: HBM actual bandwidth
The performance depends on your data pattern greatly. You can run IP example design and compare with the provided traffic.
hi @kren,
did u mean address pattern ? I think data does not play a role in this case?
Yes, it should be the address pattern.
Visitor jvl3
Short version:
I also see low efficiency. What are some guidelines for achieving a reasonable efficiency?
Long version:
I also am seeing low efficiency. I’m wondering if I just don’t understand what settings or tasking scheme is need to get a reasonable efficiency. Since it is essentially DRAM, I would have thought 70%-80% would be reasonable.
I tried the IP example design as suggested with all default settings. I modified the testbench stimuli input “csv” file to tell the testbench to write 2048 transfers, and then read 2048 transfers on AXI interface 0 “TG-0”.
This gives a transfer size of 1MB, which should take ~68us if 100% efficient. Details:
  • The transfer size should be 2048 bursts * 16 words/burst * 256 bits / 8bits/byte = 1 MB of consecutive data transfers.
  • I would think the 100% theoretical transfer rate would be 460GB/s / 32 pseudo-channels (or 32 AXI interfaces) = 14.375 GB/s per interface.
  • Time to transfer 1 MB if 100% efficient would be: 1MB / (14.375 *1024*1024*1024) = 6.79e-5 seconds (67.9 microseconds).
What I see in the testbench is:
137 uS for 1MB consecutive writes, then 154 uS for 1MB consecutive reads.
 So in the ballpark of 45%-50% efficient.
Zooming in on the waveform, I can see roughly the first 45 write bursts going at full rate, then ALL subsequent bursts (~2000 of them) slow down to about half rate. "wlast" goes from ~37ns between wlasts to ~62ns between wlasts.
I also see prolonged periods of no activity but I assume that is due to refresh, bank switch, or similar. That only accounts for maybe 15% of the time.
I have confirmed that the addresses are sequential and increment by 0x200 for each AXI burst.
What I want to understand is if this is the wrong way to access the memory. If so, what are some guidelines for getting up to a reasonable efficiency? Or did I just miscalculate or misunderstand something?
Observer davidh1901
I am also very interested in the actual bandwidth from the HBM for different burst sizes and access patterns. I'm trying to design for the vu37p part but I don't yet have a board to test it on.
Is there any information available ? The document https://www.xilinx.com/support/documentation/ip_documentation/hbm/v1_0/pg276-axi-hbm.pdf references the performance and resource use web page, but it looks like that page doesn't exist.
Hello @davidh1901,
I have a change request open to get this website created and linked properly into PG276 in a future revision.
Cory
Advisor evgenis1
Advisor
Re: HBM actual bandwidth
Hi @haiphongpham1995
I think it's both.
HBM is physically implemented as 8 memory controllers and 4 memory tiles per stack, as shown in the attached screenshots.
So if your design continuously writes to the same memory address from all 32 channels, you'd get 1/32th of the peak bandwidth.
The peak performance is achieved when accesses are spread out to non-overlapping addresses within address range of each channel (no crossbar accesses).
Evgeni
Observer davidh1901
The new version of
now has a section explaining that the crossbar switch is limited to about 50% of the maximum bandwidth. If you configurate the memory to access all of it through a single port then you are likely using the crossbar - maybe this is what you are seeing.
Our simulations show 70% or better bandwidth.
