Observer zofre_rauhut
MIG-DDR2-Control Place-Error: [Place 30-53] IDELAYCTRL instances ... have same IODELAY_GROUP 'IODELAY_MIG' but their RST signals are different.
I have a design using two DDR2-RAM-Controllers, each controller with its own SYS_CLK, CLK_REF and RST.
During place I got the following 2 errors (the path-names are replaced by ..... to keep the error message as short as possible):
[Place 30-53] IDELAYCTRL instances ...  and ... have same IODELAY_GROUP 'IODELAY_MIG' but their RST signals are different.
[Place 30-53] IDELAYCTRL instances ...  and ... have same IODELAY_GROUP 'IODELAY_MIG' but their REFCLK signals are different.
What would be the solution for this problem?
Best Regards
Bodo
Re: MIG-DDR2-Control Place-Error: [Place 30-53] IDELAYCTRL instances ... have same IODELAY_GROUP 'IODELAY_MIG' but their RST signals are different.
I got it working with the following modifications:
-> in the top-entity I changed the generic-parameter "IODELAY_GRP" for each MIG-DDR2-Module
-> the default value for the  "IODELAY_GRP" is "IODELAY_MIG"
-> after the modifcation the generic parameter for the 1st "IODELAY_GRP" was changed to "IODELAY_MIG_01"
-> and the generic parameter for the 2nd "IODELAY_GRP" was changed to "IODELAY_MIG_02"
-> after this modification the two DDR2-Controller are working
Best regards
Bodo
You need to locate the IODELAY_GROUP in the RTL for each controller and assign a unique name for each or you can regenerate a multi-controller design using MIG and MIG will automatically handle this for you.
the IODELAY_GROUP is located in the RTL for each controller, it is generated automatically by the MIG.
because I used two seperate DDR2-RAM-Controller the IODELAY_GROUP is located under the controller.
attached the structure of the 2 DDR2-RAM-controller: the iodelay_ctrl is located under each controller
does this mean, I have to rename the instance-name for each IODELAY_GROUP manually?
for a DDR2-Design this is not possible, MIG only supports multi-controller design for a DDR3-design
Best regards
Bodo
Visitor xilinxnii
I have the same problem with two chip2chip modules,
but I couldn't resolve it by this way, becouse chip2chip has no sources
and I could not change his parameters...
How it do?
I used same method, but vivado report error info:
[Place 30-51] IDELAYCTRL elements have been found to be associated with IODELAY_GROUP 'IODELAY_QDR', but the design does not contain IODELAY elements associated with this IODELAY_GROUP.
do you know what is its meaning, thank you
Visitor xilinxnii
I think this is due to the internal structure of C2C , which is hidden by the manufacturer (RSA+AES).
in Verylog, to set the IODELAY group in the *. v source element is written string
(* IODELAY_GROUP = "C2C_PHY_group" *)
in XDC we can only use existing groups, created in v (forexample: C2C_PHY_group)
Thus, when a module type Master should have to write *. v (* IODELAY_GROUP = "C2C_PHY_group_M" *), and in creating Slave (* IODELAY_GROUP = "C2C_PHY_group_S" *),
Thus in XDC we would just write :
set_property IODELAY_GROUP C2C_PHY_group_M [get_cells ...]
set_property IODELAY_GROUP C2C_PHY_group_S [get_cells ...]
Vivado in C2C always writes (* IODELAY_GROUP = "C2C_PHY_group" *)
By My mind that can solve this problem only by the manufacturer , as sources C2C closed.
Visitor jangobin
I am having a similar problem. I instantiate 4 chip2chip modulles in a virtex2000 device.
(2 masters and 2 slaves)
As decibed by xilinxii I tried to aply the following contraints :
set_property IODELAY_GROUP PCIe_C2C_PHY_group_M [get_cells {U_PCIe_C2C_bridge/PCIe_C2C_i/axi_chip2chip_0/inst}]
set_property IODELAY_GROUP PCIe_C2C_PHY_group_S [get_cells {U_PCIe_C2C_bridge/PCIe_C2C_i/axi_chip2chip_1/inst}]
set_property IODELAY_GROUP C2C_PHY_group_M [get_cells {U_C2C_wrapper/C2C_i/axi_chip2chip_0/inst}]
set_property IODELAY_GROUP C2C_PHY_group_S [get_cells {U_C2C_wrapper/C2C_i/axi_chip2chip_1/inst}]
Altough Vivado accept these contraints, I still have the issue...
How can I make Vivado understand that I would like to use a different IODELAY_GROUP for each chip2chip instance?
Are the above contraints correct?
In Advance thanks for your help!
Jan Gobin
