MIG VC707 write path
I'm using the VC707 board and i face some problems reading what i wrote on the MIG
The write path is rather unclear
What i do is that i register the data in app_wdf_data asserting app_wdf_wren when app_wdf_rdy is high
Then i assert app_en when app_rdy is high. Some times between the two assertions i wait for a couple of cycles waiting for app_rdy to get high.
The values that i write are incremented by 1 and the address that i'm writing on are also incremented by 1, so i expect when i read the memory incrementing the address read by 1 to see incrementing values on app_rd_data when app_rd_data_valid is high. But it is not what i see
I have 3 main questions
1) It is said in the Guide that i can register the data before the app_cmd is asserted but is there a maximum delay?
2) If app_rdy = '1' for a moment and on the next rising edge(1) of ui_clk i assert app_en and on the next risng edge(2)  of ui_clk i deassert app_en and i realize that app_rdy is ='0' before that last rising edge (2) of ui_clk , I assume that app_cmd has not been validated right?
3) If app_en = '1'for a moment and after the rising edge (1) of ui_clk app_rdy gets high and stays high and on the next rising edge(2) of ui_clk i deassert app_en while app_rdy is still high , How many app_cmd have been validated here one or two?
Here is an image to clarify
Here is my MIG controller which asserts the different signals:
-- Company:
-- Engineer:
-- Create Date: 25.07.2018 11:25:05
-- Design Name:
-- Module Name: MIG_CONTROLLER - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity MIG_CONTROLLER is
    Port ( ui_clk                    : IN     std_logic;
           ACTIVE_TX                 : in     std_logic;
           rx_dv                     : in     STD_LOGIC;
           rx_byte                   : in     STD_LOGIC_VECTOR (7 downto 0);
           TX_Done                   : in     STD_LOGIC;
           TX_DV                     : out    STD_LOGIC;
           TX_Byte                   : out    STD_LOGIC_VECTOR(7 downto 0);
           missing_pkts              : in     std_logic;
           missing_pkts_read         : out    std_logic;
           rd_en_fifo1               : out    std_logic;
           dout_fifo1                : in     std_logic_vector(31 downto 0);
           wr_en_fifo2               : out    std_logic;
           empty_fifo2               : in     std_logic;
           empty_fifo1               : in    std_logic;
           write_mig_complete        : out    std_logic;
           final_address             : out    std_logic_vector( 24 downto 0);
           prog_full_FIFO3           : in     STD_LOGIC;
           ethernet_done             : in     std_logic;
           read_mig_complete         : out    STD_LOGIC;
           rst_fifo                  : out    STD_LOGIC;
           wr_rst_busy               : in     STD_LOGIC;
           rd_rst_busy               : in     STD_LOGIC;
           transfer_done             : out    STD_LOGIC;
           app_addr                  : OUT    std_logic_vector(27 downto 0);
           app_cmd                   : OUT    std_logic_vector(2 downto 0);
           app_en                    : OUT    std_logic;
           app_wdf_data              : OUT    std_logic_vector(511 downto 0);
           app_wdf_end               : OUT    std_logic;
           app_wdf_mask              : OUT    std_logic_vector(63 downto 0);
           app_wdf_wren              : OUT    std_logic;
           app_rd_data               : IN     std_logic_vector(511 downto 0);
           app_rd_data_end           : IN     std_logic;
           app_rd_data_valid         : IN     std_logic;
           app_rdy                   : IN     std_logic;
           app_wdf_rdy               : IN     std_logic;
           RESET                     : IN     std_logic;
           debug_etat                : out    std_logic_vector(7 downto 0);
           init_calib_complete       : IN     std_logic
end MIG_CONTROLLER;
architecture Behave of MIG_CONTROLLER is
type type_etat is (INIT,RESETFIFO, DETECTFULL, FIFOREADY, WAIT_TRANSFER, SEND_SERIAL, TEMPO_SERIAL,
                   SEND_SERIAL1, TEMPO_SERIAL1,
                   CALIB_COMPLETE,READ_FIFO2,RF_WM,WM,CHECK,TEMPO_WM, SEND_WORD1,TEMPO1, TEMPO_READ1,
                   TEMPO_READ2,TEMPO_READ3,WDF_END,CHECK_WDF,APP_ENV,CHECK_APP_ENV,
                   READ_MISSING_PKTS,
                   READ_FIFO_ADD_MP ,       TEMPO_READ_FIFO2,
                   READ_MIG_MP      ,
                   CHECK_READ_MP    ,
                   TEMPO_NO_INCREMENT_MP   ,     WAIT_DATA_VALID,
                   READ_MIG_MP_NO_INCREMENT,READ_MIG_MP_COMPLETE,TEMPO_READ_MIG_MP_COMPLETE,
                   READ_MIG,CHECK_READ,TEMPO_NO_INCREMENT,READ_MIG_NO_INCREMENT,
                   READ_COMPLETE,WAIT_ETHERNET,ETHERNET_COMPLETE
signal etat : type_etat;
signal tb_WORD : std_logic_vector(23 downto 0);
signal tb_word_to_write : unsigned(23 downto 0);
signal tb_dout_fifo1 : std_logic_vector(31 downto 0);
signal enable : std_logic;
signal address    : unsigned (24 downto 0) := "0000000000000000000000000";
signal tb_address    : unsigned (24 downto 0) := "0000000000000000000000000";
signal tb_final_address : unsigned (24 downto 0) :=  "0000000000000000000000000";
signal count : unsigned (23 downto 0):= x"000000";
signal compt1     : unsigned (2 downto 0) := "000";
signal raz        : std_logic;
begin
tb_dout_fifo1(7 downto 0)  <= dout_fifo1(31 downto 24);
tb_dout_fifo1(15 downto 8) <= dout_fifo1(23 downto 16);
tb_dout_fifo1(23 downto 16) <= dout_fifo1(15 downto 8);
tb_dout_fifo1(31 downto 24) <= dout_fifo1(7 downto 0);
app_addr <= std_logic_vector(address)&"000";
final_address <= std_logic_vector(tb_final_address);
app_wdf_mask  <= (others=>'0');
app_wdf_data (511 downto 24) <= (others=>'0');
app_wdf_data(23 downto 0) <= std_logic_vector(tb_word_to_write);
process (ui_clk)
begin
if rising_edge(ui_clk) then
    if raz ='1' then
        compt1 <= "000";
    else
        compt1 <= compt1 + 1;
    end if;
end if;
end process;
   process (UI_CLK,RESET)
   begin
   if RESET = '1' then
       etat <= INIT;
   elsif rising_edge (UI_CLK) then
       case etat is
           when INIT                   => etat <= RESETFIFO;-- if (ACTIVE_TX = '0' ) then etat <= SEND_SERIAL1; end if; debug_etat <= x"00";
           when SEND_SERIAL1            => etat <= TEMPO_SERIAL1;debug_etat <= x"01";
           when TEMPO_SERIAL1           => if ( tx_done = '1' ) then etat <= RESETFIFO; end if;debug_etat <= x"02";
           when RESETFIFO              => if (compt1 = "111") then etat <= DETECTFULL; end if;debug_etat <= x"03";
           when DETECTFULL             => if (wr_rst_busy ='0' and rd_rst_busy='0') then etat <= FIFOREADY; end if;
           debug_etat <= x"04";
           when WAIT_TRANSFER          => if (rx_dv = '1' and rx_byte /= "10010101") then
                                             etat <= WAIT_TRANSFER;
                                          elsif (rx_dv = '1' and rx_byte = "10010101" and ACTIVE_TX = '0') then
                                             etat <= SEND_SERIAL;
                                          end if;
           debug_etat <= x"05";
           when SEND_SERIAL            => etat <= TEMPO_SERIAL;
           debug_etat <= x"06";
           when TEMPO_SERIAL           => if ( tx_done = '1' ) then etat <= FIFOREADY; end if;
           debug_etat <= x"07";
           when FIFOREADY              =>  if init_calib_complete = '1' then
                                               etat <= CALIB_COMPLETE;
                                           end if;
             debug_etat <= x"08";
           when CALIB_COMPLETE  => etat <= READ_FIFO2;
           debug_etat <= x"09";
           when READ_FIFO2      => if (count = x"000200") then
                                       etat <= TEMPO_READ1;
                                   else
                                       etat <= TEMPO_READ_FIFO2;
                                   end if;
           when TEMPO_READ_FIFO2 => etat <= WDF_END;
           when WDF_END         => if (app_wdf_rdy = '1') then etat <= CHECK_WDF; end if;
           when CHECK_WDF       => if (app_wdf_rdy = '1') then
                                       etat <= APP_ENV;
                                   else
                                       etat <= WDF_END;
                                   end if;
           when APP_ENV         => if (app_rdy = '1') then etat <= CHECK_APP_ENV; end if;
           when CHECK_APP_ENV   => if (app_rdy = '1') then
                                       etat <= READ_FIFO2;
                                   else
                                       etat <= APP_ENV;
                                   end if;
           when TEMPO_READ1              => etat <= TEMPO_READ2;
           debug_etat <= x"0F";
           when TEMPO_READ2              => etat <= TEMPO_READ3;
           debug_etat <= x"10";
           when TEMPO_READ3              => if (app_rdy = '1') then
                                               etat <= READ_MIG;
                                           end if;
                                           debug_etat <= x"11";
           when READ_MIG                => etat <= CHECK_READ;
           debug_etat <= x"12";
           when CHECK_READ              => if (address = tb_final_address - 1) then etat <= READ_COMPLETE;
                                           elsif (app_rdy = '1'and prog_full_FIFO3 = '0') then etat <= READ_MIG;
                                           elsif (app_rdy = '0'and prog_full_FIFO3 = '0') then etat <= TEMPO_NO_INCREMENT;
                                           end if;
                                           debug_etat <= x"13";
           when TEMPO_NO_INCREMENT      =>  if (address = tb_final_address - 1) then etat <= READ_COMPLETE;
                                            elsif (app_rdy ='1'and prog_full_FIFO3 = '0') then etat <= READ_MIG_NO_INCREMENT; end if;
                                            debug_etat <= x"14";
           when READ_MIG_NO_INCREMENT   => etat <= CHECK_READ;
           debug_etat <= x"15";
           when READ_COMPLETE           => etat <= WAIT_ETHERNET;
           debug_etat <= x"16";
           when WAIT_ETHERNET           => if (ethernet_done = '1') then etat <= ETHERNET_COMPLETE;
                                           elsif (missing_pkts = '1') then etat <= READ_MISSING_PKTS; end if;
                                           debug_etat <= x"17";
           when READ_MISSING_PKTS       => etat <= READ_FIFO_ADD_MP;
           debug_etat <= x"18";
           when READ_FIFO_ADD_MP        => etat <= READ_MIG_MP;
           debug_etat <= x"19";
           when READ_MIG_MP             => etat <= CHECK_READ_MP;
           debug_etat <= x"1A";
           when CHECK_READ_MP              => if (empty_fifo1 = '1') then etat <= READ_MIG_MP_COMPLETE;
                                           elsif(app_rdy = '1' ) then etat <= WAIT_DATA_VALID;
                                           elsif (app_rdy = '0') then etat <= TEMPO_NO_INCREMENT_MP;
                                           end if;
                                           debug_etat <= x"1B";
           when TEMPO_NO_INCREMENT_MP      =>  if (empty_fifo1 = '1') then etat <= READ_MIG_MP_COMPLETE;
                                            elsif (app_rdy ='1') then etat <= READ_MIG_MP_NO_INCREMENT; end if;
                                            debug_etat <= x"1C";
           when READ_MIG_MP_COMPLETE       =>   etat <= TEMPO_READ_MIG_MP_COMPLETE;
           debug_etat <= x"1D";
           when TEMPO_READ_MIG_MP_COMPLETE =>   if (ethernet_done = '1') then etat <= ETHERNET_COMPLETE;
                                                  debug_etat <= x"1E";
           when READ_MIG_MP_NO_INCREMENT   => etat <= CHECK_READ_MP;
           debug_etat <= x"1F";
           when WAIT_DATA_VALID              => if (app_rd_data_valid = '1') then  etat <= READ_FIFO_ADD_MP; end if;
           when ETHERNET_COMPLETE       => etat <= INIT;
           debug_etat <= x"20";
           when others => etat <= INIT;
       end case;
   end if;
   end process;
   --tb_WORD <= app_rd_data(23 downto 0) when (etat = WAIT_READ_WORD1 and app_rd_data_valid = '1');
   process (ui_clk)
   begin
   if rising_edge (ui_clk) then
   if (etat = INIT) then
       raz               <= '1';
       rst_fifo          <= '0';
       transfer_done     <= '0';
       read_mig_complete <= '0';
       app_en            <= '0';
       app_cmd           <= "000";
       app_wdf_wren      <= '0';
       app_wdf_end       <= '0';
       address           <= (others =>'0');
       tb_word_to_write  <= (others =>'0');
       count             <= x"000000";
       write_mig_complete <= '0';
       missing_pkts_read <= '0';
       TX_DV   <= '0';
       TX_Byte <= "00000000";
       rd_en_fifo1   <= '0';
          elsif (etat = SEND_SERIAL1) then
           TX_DV   <= '1';
           TX_Byte <= "01000001";
       elsif (etat = TEMPO_SERIAL1) then
           TX_DV   <= '0';
   elsif (etat = SEND_SERIAL) then
       TX_DV   <= '1';
       TX_Byte <= "10101010";
   elsif (etat = TEMPO_SERIAL) then
       TX_DV   <= '0';
   elsif (etat = RESETFIFO) then
       raz               <= '0';
       rst_fifo          <= '1';
       app_en            <= '0';
       app_cmd           <= "000";
       app_wdf_end       <= '0';
       count             <= x"000000";
   elsif (etat = DETECTFULL) then
       app_en        <= '0';
       rst_fifo      <= '0';
       address       <= (others=>'0');
       app_wdf_end   <= '0';
       app_cmd       <= "000";
   elsif (etat = FIFOREADY) then
       app_en        <= '0';
       app_wdf_end   <= '0';
       app_cmd       <= "000";
   elsif (etat = CALIB_COMPLETE)then
       app_en       <= '0';
       app_cmd      <= "000";
       app_wdf_end  <= '0';
   elsif (etat = READ_FIFO2)then
       app_en       <= '0';
       app_cmd      <= "000";
       app_wdf_end  <= '0';
       address      <= address + 1;
       tb_word_to_write <= tb_word_to_write + 1;
       count            <= count + 1;
  elsif (etat = WDF_END)then
                app_en       <= '0';
                app_cmd      <= "000";
                app_wdf_wren <= '1';
                app_wdf_end  <= '1';
                app_cmd      <= "000";
           elsif (etat = APP_ENV)then
                        app_en       <= '1';
                        app_cmd      <= "000";
                        app_wdf_end  <= '0';
                        app_cmd      <= "000";
        elsif (etat = CHECK_WDF)then
            app_en       <= '0';
            app_cmd      <= "000";
            app_wdf_end  <= '0';
         elsif (etat = CHECK_APP_ENV)then
                app_en       <= '0';
                app_cmd      <= "000";
                app_wdf_end  <= '0';
elsif (etat = TEMPO_READ1 ) then
    raz           <= '0';
    app_en        <= '0';
    rst_fifo      <= '0';
    app_wdf_end   <= '0';
    app_cmd       <= "001";
    tb_final_address <= address;
elsif (etat = TEMPO_READ3 ) then
        raz           <= '0';
        app_en        <= '0';
        rst_fifo      <= '0';
        app_wdf_end   <= '0';
        app_cmd       <= "001";
        write_mig_complete <= '1';
elsif (etat = READ_MIG) then
    app_en        <= '1';
    app_wdf_end   <= '0';
    app_cmd       <= "001";
elsif (etat = CHECK_READ ) then
    app_en        <= '0';
    address       <= address;
    app_wdf_end   <= '0';
    app_cmd       <= "001";
elsif (etat = TEMPO_NO_INCREMENT) then
    app_en        <= '0';
    address       <= address ;
    app_wdf_end   <= '0';
    app_cmd       <= "001";
elsif (etat = READ_MIG_NO_INCREMENT) then
    app_en        <= '1';
    app_wdf_end   <= '0';
    app_cmd       <= "001";
elsif (etat = READ_COMPLETE) then
    app_en        <= '0';
    app_wdf_end   <= '0';
    app_cmd       <= "001";
    read_mig_complete <= '1';
elsif (etat = WAIT_ETHERNET) then
    app_en        <= '0';
    app_wdf_end   <= '0';
    app_cmd       <= "001";
elsif (etat = ETHERNET_COMPLETE) then
    app_en        <= '0';
    app_wdf_end   <= '0';
    app_cmd       <= "001";
    transfer_done <= '1';
elsif (etat = READ_MISSING_PKTS) then
    app_en        <= '0';
    app_wdf_end   <= '0';
    app_cmd       <= "001";
elsif (etat = READ_FIFO_ADD_MP) then
    rd_en_fifo1   <= '1';
elsif (etat = READ_MIG_MP) then
    rd_en_fifo1   <= '0';
    app_en        <= '1';
    address       <= unsigned(tb_dout_fifo1(24 downto 0));
    app_cmd       <= "001";
elsif (etat = CHECK_READ_MP) then
    app_en        <= '0';
    app_cmd       <= "001";
elsif (etat = WAIT_DATA_VALID) then
        app_en        <= '0';
        app_cmd       <= "001";
elsif (etat = TEMPO_NO_INCREMENT_MP) then
    app_en        <= '0';
    app_cmd       <= "001";
elsif (etat = READ_MIG_MP_NO_INCREMENT) then
    app_en        <= '1';
    app_cmd       <= "001";
elsif (etat = READ_MIG_MP_COMPLETE) then
    app_en        <= '0';
    app_cmd       <= "001";
    missing_pkts_read <= '1';
elsif (etat = TEMPO_READ_MIG_MP_COMPLETE) then
        app_en        <= '0';
        app_cmd       <= "001";
   else
       app_en       <= '0';
       app_cmd      <= "000";
       app_wdf_end  <= '0';
   end if;
   end if;
end process;
end Behave;
Voyager
Voyager
Re: MIG VC707 write path
I don't think so. From the MIG UG586:
app_wdf_data data can be pushed even before app_cmd "write command" is asserted. The only condition is that for every app_cmd "write command," the associated app_wdf_data "write data" must be present.
So there doesn't seem to be a clock-cycle limit on the pre-arrival of data before the associated write command.
Your assumption is (probably) correct. But your actions are wrong. From the MIG UG:
app_rdy
This output indicates to you whether the request currently being submitted to the UI is accepted. If the UI does not assert this signal after app_en is asserted, the current request must be retried.
So while the controller can play peek-a-boo with the app_rdy (and the app_wdf_rdy), your interface logic must maintain your enables until the controller accepts the transaction. You should not "deassert app_en" until the transaction has been accepted by the controller.
I don't follow you narration of events. What does "for a moment" mean?
You should have labeled the clock edges in your drawing with the edge numbers you used in your questions, if they're supposed to be related...
In the first case, 1 DDR command is accepted into the controller; in the second case, 2.
-Joe G.
Voyager
Voyager
app_rdy
-Joe G.
