Visitor gopal_123
Need a suggestion in selecting a micro SDIO card to Emulate SDIO host controller IP on Xilinx vcu118 kit
Hi All,
I want to test SDIO IP controller on xilinx vcu118 Emulation board with an Emulation peripheral daughter board ( on which there is micro SD slot to insert SDIO card)
For this, i need micro SDIO card. Can some one please suggest me a Micro SDIO card and where to get that?
Re: Need a suggestion in selecting a micro SDIO card to Emulate SDIO host controller IP on Xilinx vcu118 kit
Hello @gopal_123,
SDIO is just an electrical interface standard, a slower and older one at that, for interfacing with the Secure Digital memory card format.  Most likely slower and less feature rich SDCards will be able to communicate over an SDIO interface.  You'll need to double check the clock rate, voltages, and basic setup/hold time parameters of the SDIO controller IP against the SDCard device data sheets.  There aren't many parameters so it should be rather quick.
Looking at the VC118 user guide in UG1124 it looks to be a standard 50MHz SD card interface from a Zynq-7000 device. However the SD card is used for the Zynq as part of the system controller. This isn't connected to the XCVU9P so you won't be able to communicate with it.
Here's a link to the latest version of UG1224:
https://www.xilinx.com/support/documentation/boards_and_kits/vcu118/ug1224-vcu118-eval-bd.pdf
