Random DDR3 Write Failures
I am bringing up a new Ultrascale design using DDR3.  The design always passes calibration but randomly has write failures.   Some of the bytes in the calibration margin window are highlighted orange.  I'm wondering if this may be contributing to my random write failures.  Should I be concerned by these orange highlights?
Re: Random DDR3 Write Failures
which device and core version.
check this ARs in case helps
https://www.xilinx.com/support/answers/35094.html
Thanks and Regards
Balkrishan
I'm using an Ultrascale XCKU035.  The DDR3 core is DDR3 SDRAM  (MIG) (1.1) in Vivado 2015.4.
Kudos: 788
Solutions: 1,015
Hi @jduchez
What is the memory clock frequency? Are you following all design guidelines from PG150?
Deepika.
