Observer vikashurgat
SD card interface with the ZC702
I want to interface SD card with xilinx Zc702 board,i am using vivado.
I am not able to add SD card host controller ip with the node locked license i received with the evaluation board.
What are the possible ways to do read and write to the SD card? Is it possible without adding an SD card host controller ip?
Re: SD card interface with the ZC702
check these links
http://www.wiki.xilinx.com/Boot+Pre-Built+Xilinx+ZC-702+image
http://www.xilinx.com/support/answers/54012.html
http://www.wiki.xilinx.com/Zc702+Linux
http://www.xilinx.com/support/answers/52538.html
https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Zynq-booting-from-SD-Card/td-p/470062
https://forums.xilinx.com/t5/Embedded-Linux/linux-booting-problem-from-SD-card-zynq-zc702/td-p/308471
Thanks and Regards
Balkrishan
Hello Mr Balkrishna,
Thanks for the links you provided,but the links that  you provided doesn't solve my issue.
I want to keep some text document into SD card and i want to read the text file in my application.
I working on standalone OS and not on linux(I dont want to boot linux from the SD card).
vikas.
Voyager
Voyager
@vikashurgat,
Have you thought about an OpenSource core from OpenCores?  There are two: one that uses the full SDIO interface, and another that uses the SPI interface (that's mine).
Dan
Visitor sivabharani
Hai,
        Have you cleared the problem you mentioned above,if it is please send me.
Hello @sivabharani,
It's always best to create a new topic when you have a question because it increases visibility.
Take a look at this thread:
https://forums.xilinx.com/t5/Embedded-Linux/SD-card-device-driver/m-p/419675/highlight/true#M7995
If that doesn't work then please create a new topic in the Embedded Processor System Design forum.
