Test the performance of DDR4
My design has 1GB DDR4(2400P) which is attached to PL of Zynq Ultrasclae+ device.
I want to make a test code to verify if this DDR4 can work well under different ambient temperature.
Is there any existing cold from Xilinx I can use them directly with a minimum of modification?
Re: Test the performance of DDR4
XTP432 is specifically for testing PL MIG on the ZCU102. We also have XTP431 for a quick IPI design bring up to test out most if not all the interfaces on the ZCU102. You can mimic these XTP’s for your own application.
Cory
Cory
