VCU118 DDR4 MIG xdc warning with vivado2016.4: No pins matched
set_multicycle_path -setup 8 -from [get_pins */u_ddr_cal_top/calDone*/C]
set_multicycle_path -end -hold 7 -from [get_pins */u_ddr_cal_top/calDone*/C]
set_false_path -hold -to [get_pins */*/*/*/*/*.u_xiphy_control/xiphy_control/RIU_ADDR*]
set_false_path -hold -to [get_pins */*/*/*/*/*.u_xiphy_control/xiphy_control/RIU_WR_DATA*]
set_max_delay 5.0 -datapath_only -from [get_pins */*/*/u_ddr_cal_addr_decode/io_ready_lvl_reg/C] -to [get_pins */u_io_ready_lvl_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 5.0 -datapath_only -from [get_pins */*/*/u_ddr_cal_addr_decode/io_read_data_reg[*]/C] -to [get_pins */u_io_read_data_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins */*/*/phy_ready_riuclk_reg/C] -to [get_pins */u_phy2clb_phy_ready_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins */*/*/bisc_complete_riuclk_reg/C] -to [get_pins */u_phy2clb_bisc_complete_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins */*/io_addr_strobe_lvl_riuclk_reg/C] -to [get_pins */u_io_addr_strobe_lvl_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins */*/io_write_strobe_riuclk_reg/C] -to [get_pins */u_io_write_strobe_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins */*/io_address_riuclk_reg[*]/C] -to [get_pins */u_io_addr_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins */*/io_write_data_riuclk_reg[*]/C] -to [get_pins */u_io_write_data_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 10.0 -datapath_only -from [get_pins */en_vtc_in_reg/C] -to [get_pins */u_en_vtc_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 10.0 -datapath_only -from [get_pins */*/riu2clb_valid_r1_riuclk_reg[*]/C] -to [get_pins */u_riu2clb_valid_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 10.0 -datapath_only -from [get_pins */*/*/phy2clb_fixdly_rdy_low_riuclk_int_reg[*]/C] -to [get_pins */u_phy2clb_fixdly_rdy_low/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 10.0 -datapath_only -from [get_pins */*/*/phy2clb_fixdly_rdy_upp_riuclk_int_reg[*]/C] -to [get_pins */u_phy2clb_fixdly_rdy_upp/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 10.0 -datapath_only -from [get_pins */*/*/phy2clb_phy_rdy_low_riuclk_int_reg[*]/C] -to [get_pins */u_phy2clb_phy_rdy_low/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 10.0 -datapath_only -from [get_pins */*/*/phy2clb_phy_rdy_upp_riuclk_int_reg[*]/C] -to [get_pins */u_phy2clb_phy_rdy_upp/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 10.0 -datapath_only -from [get_pins */rst_r1_reg/C] -to [get_pins */u_fab_rst_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins  */*/*/clb2phy_t_b_addr_riuclk_reg/C] -to [get_pins  */*/*/clb2phy_t_b_addr_i_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins  */*/*/*/slave_en_lvl_reg/C] -to [get_pins  */*/*/*/u_slave_en_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins  */*/*/*/slave_we_r_reg/C] -to [get_pins  */*/*/*/u_slave_we_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins  */*/*/*/slave_addr_r_reg[*]/C] -to [get_pins  */*/*/*/u_slave_addr_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins  */*/*/*/slave_di_r_reg[*]/C] -to [get_pins  */*/*/*/u_slave_di_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 3.0 -datapath_only -from [get_pins  */*/*/*/slave_rdy_cptd_sclk_reg/C] -to [get_pins  */*/*/*/u_slave_rdy_cptd_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 12.0 -datapath_only -from [get_pins */*/*/*/slave_rdy_lvl_fclk_reg/C] -to [get_pins  */*/*/*/u_slave_rdy_sync/SYNC[*].sync_reg_reg[0]/D]
set_max_delay 12.0 -datapath_only -from [get_pins */*/*/*/slave_do_fclk_reg[*]/C] -to [get_pins  */*/*/*/u_slave_do_sync/SYNC[*].sync_reg_reg[0]/D]
set_false_path -through [get_pins u_ddr4_infrastructure/sys_rst]
set_false_path -from [get_pins  */input_rst_design_reg/C] -to [get_pins */rst_div_sync_r_reg[0]/D]
set_false_path -from [get_pins  */input_rst_design_reg/C] -to [get_pins */rst_riu_sync_r_reg[0]/D]
set_false_path -from [get_pins  */input_rst_design_reg/C] -to [get_pins */rst_mb_sync_r_reg[0]/D]
set_false_path -from [get_pins  */rst_async_riu_div_reg/C] -to [get_pins */rst_div_sync_r_reg[0]/D]
set_false_path -from [get_pins  */rst_async_mb_reg/C]      -to [get_pins */rst_mb_sync_r_reg[0]/D]
set_false_path -from [get_pins  */rst_async_riu_div_reg/C] -to [get_pins */rst_riu_sync_r_reg[0]/D]
WARNING: [Vivado 12-508] No pins matched '*/u_ddr_cal_top/calDone*/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:257]
CRITICAL WARNING: [Vivado 12-4739] set_multicycle_path:No valid object(s) found for '-from [get_pins */u_ddr_cal_top/calDone*/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:257]
Resolution: Check if the specified object(s) exists in the current design. If it does, ensure that the correct design hierarchy was specified for the object. If you are working with clocks, make sure create_clock was used to create the clock object before it is referenced.
WARNING: [Vivado 12-508] No pins matched '*/u_ddr_cal_top/calDone*/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:258]
CRITICAL WARNING: [Vivado 12-4739] set_multicycle_path:No valid object(s) found for '-from [get_pins */u_ddr_cal_top/calDone*/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:258]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/*/*.u_xiphy_control/xiphy_control/RIU_ADDR*'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:265]
CRITICAL WARNING: [Vivado 12-4739] set_false_path:No valid object(s) found for '-to [get_pins */*/*/*/*/*.u_xiphy_control/xiphy_control/RIU_ADDR*]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:265]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/*/*.u_xiphy_control/xiphy_control/RIU_WR_DATA*'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:266]
CRITICAL WARNING: [Vivado 12-4739] set_false_path:No valid object(s) found for '-to [get_pins */*/*/*/*/*.u_xiphy_control/xiphy_control/RIU_WR_DATA*]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:266]
WARNING: [Vivado 12-508] No pins matched '*/*/*/u_ddr_cal_addr_decode/io_ready_lvl_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:285]
WARNING: [Vivado 12-508] No pins matched '*/u_io_ready_lvl_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:285]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/*/u_ddr_cal_addr_decode/io_ready_lvl_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:285]
WARNING: [Vivado 12-508] No pins matched '*/*/*/u_ddr_cal_addr_decode/io_read_data_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:286]
WARNING: [Vivado 12-508] No pins matched '*/u_io_read_data_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:286]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/*/u_ddr_cal_addr_decode/io_read_data_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:286]
WARNING: [Vivado 12-508] No pins matched '*/*/*/phy_ready_riuclk_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:287]
WARNING: [Vivado 12-508] No pins matched '*/u_phy2clb_phy_ready_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:287]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/*/phy_ready_riuclk_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:287]
WARNING: [Vivado 12-508] No pins matched '*/*/*/bisc_complete_riuclk_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:288]
WARNING: [Vivado 12-508] No pins matched '*/u_phy2clb_bisc_complete_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:288]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/*/bisc_complete_riuclk_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:288]
WARNING: [Vivado 12-508] No pins matched '*/*/io_addr_strobe_lvl_riuclk_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:289]
WARNING: [Vivado 12-508] No pins matched '*/u_io_addr_strobe_lvl_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:289]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/io_addr_strobe_lvl_riuclk_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:289]
WARNING: [Vivado 12-508] No pins matched '*/*/io_write_strobe_riuclk_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:290]
WARNING: [Vivado 12-508] No pins matched '*/u_io_write_strobe_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:290]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/io_write_strobe_riuclk_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:290]
WARNING: [Vivado 12-508] No pins matched '*/*/io_address_riuclk_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:291]
WARNING: [Vivado 12-508] No pins matched '*/u_io_addr_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:291]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/io_address_riuclk_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:291]
WARNING: [Vivado 12-508] No pins matched '*/*/io_write_data_riuclk_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:292]
WARNING: [Vivado 12-508] No pins matched '*/u_io_write_data_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:292]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/io_write_data_riuclk_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:292]
WARNING: [Vivado 12-508] No pins matched '*/en_vtc_in_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:293]
WARNING: [Vivado 12-508] No pins matched '*/u_en_vtc_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:293]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */en_vtc_in_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:293]
WARNING: [Vivado 12-508] No pins matched '*/*/riu2clb_valid_r1_riuclk_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:294]
WARNING: [Vivado 12-508] No pins matched '*/u_riu2clb_valid_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:294]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/riu2clb_valid_r1_riuclk_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:294]
WARNING: [Vivado 12-508] No pins matched '*/*/*/phy2clb_fixdly_rdy_low_riuclk_int_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:295]
WARNING: [Vivado 12-508] No pins matched '*/u_phy2clb_fixdly_rdy_low/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:295]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/*/phy2clb_fixdly_rdy_low_riuclk_int_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:295]
WARNING: [Vivado 12-508] No pins matched '*/*/*/phy2clb_fixdly_rdy_upp_riuclk_int_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:296]
WARNING: [Vivado 12-508] No pins matched '*/u_phy2clb_fixdly_rdy_upp/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:296]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/*/phy2clb_fixdly_rdy_upp_riuclk_int_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:296]
WARNING: [Vivado 12-508] No pins matched '*/*/*/phy2clb_phy_rdy_low_riuclk_int_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:297]
WARNING: [Vivado 12-508] No pins matched '*/u_phy2clb_phy_rdy_low/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:297]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/*/phy2clb_phy_rdy_low_riuclk_int_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:297]
WARNING: [Vivado 12-508] No pins matched '*/*/*/phy2clb_phy_rdy_upp_riuclk_int_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:298]
WARNING: [Vivado 12-508] No pins matched '*/u_phy2clb_phy_rdy_upp/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:298]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/*/phy2clb_phy_rdy_upp_riuclk_int_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:298]
WARNING: [Vivado 12-508] No pins matched '*/rst_r1_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:299]
WARNING: [Vivado 12-508] No pins matched '*/u_fab_rst_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:299]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */rst_r1_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:299]
WARNING: [Vivado 12-508] No pins matched '*/*/*/clb2phy_t_b_addr_riuclk_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:300]
WARNING: [Vivado 12-508] No pins matched '*/*/*/clb2phy_t_b_addr_i_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:300]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/*/clb2phy_t_b_addr_riuclk_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:300]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/slave_en_lvl_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:301]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/u_slave_en_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:301]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/*/*/slave_en_lvl_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:301]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/slave_we_r_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:302]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/u_slave_we_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:302]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/*/*/slave_we_r_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:302]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/slave_addr_r_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:303]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/u_slave_addr_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:303]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/*/*/slave_addr_r_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:303]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/slave_di_r_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:304]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/u_slave_di_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:304]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/*/*/slave_di_r_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:304]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/slave_rdy_cptd_sclk_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:305]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/u_slave_rdy_cptd_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:305]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/*/*/slave_rdy_cptd_sclk_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:305]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/slave_rdy_lvl_fclk_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:306]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/u_slave_rdy_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:306]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins */*/*/*/slave_rdy_lvl_fclk_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:306]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/slave_do_fclk_reg[*]/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:307]
WARNING: [Vivado 12-508] No pins matched '*/*/*/*/u_slave_do_sync/SYNC[*].sync_reg_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:307]
CRITICAL WARNING: [Vivado 12-4739] set_max_delay:No valid object(s) found for '-from [get_pins {*/*/*/*/slave_do_fclk_reg[*]/C}]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:307]
WARNING: [Vivado 12-508] No pins matched 'u_ddr4_infrastructure/sys_rst'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:308]
CRITICAL WARNING: [Vivado 12-4739] set_false_path:No valid object(s) found for '-through [get_pins u_ddr4_infrastructure/sys_rst]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:308]
WARNING: [Vivado 12-508] No pins matched '*/input_rst_design_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:309]
WARNING: [Vivado 12-508] No pins matched '*/rst_div_sync_r_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:309]
CRITICAL WARNING: [Vivado 12-4739] set_false_path:No valid object(s) found for '-from [get_pins */input_rst_design_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:309]
WARNING: [Vivado 12-508] No pins matched '*/input_rst_design_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:310]
WARNING: [Vivado 12-508] No pins matched '*/rst_riu_sync_r_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:310]
CRITICAL WARNING: [Vivado 12-4739] set_false_path:No valid object(s) found for '-from [get_pins */input_rst_design_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:310]
WARNING: [Vivado 12-508] No pins matched '*/input_rst_design_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:311]
WARNING: [Vivado 12-508] No pins matched '*/rst_mb_sync_r_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:311]
CRITICAL WARNING: [Vivado 12-4739] set_false_path:No valid object(s) found for '-from [get_pins */input_rst_design_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:311]
WARNING: [Vivado 12-508] No pins matched '*/rst_async_riu_div_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:312]
WARNING: [Vivado 12-508] No pins matched '*/rst_div_sync_r_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:312]
CRITICAL WARNING: [Vivado 12-4739] set_false_path:No valid object(s) found for '-from [get_pins */rst_async_riu_div_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:312]
WARNING: [Vivado 12-508] No pins matched '*/rst_async_mb_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:313]
WARNING: [Vivado 12-508] No pins matched '*/rst_mb_sync_r_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:313]
CRITICAL WARNING: [Vivado 12-4739] set_false_path:No valid object(s) found for '-from [get_pins */rst_async_mb_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:313]
WARNING: [Vivado 12-508] No pins matched '*/rst_async_riu_div_reg/C'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:314]
WARNING: [Vivado 12-508] No pins matched '*/rst_riu_sync_r_reg[0]/D'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:314]
CRITICAL WARNING: [Vivado 12-4739] set_false_path:No valid object(s) found for '-from [get_pins */rst_async_riu_div_reg/C]'. [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc:314]
Finished Parsing XDC File [e://xilinx_vcu118_ip/xilinx_vcu118_ip/xilinx_vcu118_ip.srcs/sources_1/ip/ddr4_1/par/ddr4_1.xdc]
Kudos: 764
Solutions: 1,007
Re: VCU118 DDR4 MIG xdc warning with vivado2016.4: No pins matched
Hi @m006
Are you still seeing this issue?
What flow are you using?
Deepika.
