app_rdy signal is at low
hi all,
i am doing my vivado project in KC705 board. I am using both MIG and pcie. pcie side is working and i am getting data through pcie(verified using ILA core). but my MIG interface is not properly working. app_wdf_rdy signal is high but app_rdy is low. i mapped init_calib_complete to one led, but it is not glowing. can anyone help me? please.
mig ipcore details attached.
Thanks in advance.
Reshma
Re: app_rdy signal is at low
check this post and follow suggestions
https://forums.xilinx.com/t5/Memory-Interfaces/app-rdy-and-app-wdf-rdy-signals-is-at-low/m-p/741943
Thanks and Regards
Balkrishan
hi @balkris,
thanks for your reply.
I already completed the steps mentioned in the post
after that only i was able complete bit stream generation. and now the app_wdf_rdy signal is high. problem is with the other one.
Reshma
Please check blow links for app_rdy low reasons
http://www.xilinx.com/support/answers/36719.html
http://forums.xilinx.com/t5/MIG-Memory-Interface-Generator/MIG-7-series-Gap-in-continuous-write-read/td-p/365643
http://www.xilinx.com/support/answers/56276.html
If you notice any specific scenario of unexpected app_rdy low periods then please elaborate and share the waveforms
Thanks and Regards
Balkrishan
Kudos: 788
Solutions: 1,015
[ Edited ]
Hi @reshmaakhil
The app_rdy might be low as calibration is not successful i.e., init_calib_complete is low.
Are you using KC705 board or custom board?
Please do the general checks mentioned in page-232 of UG586 https://www.xilinx.com/support/documentation/ip_documentation/mig_7series/v4_1/ug586_7Series_MIS.pdf
Also identify which stage of calibration is failing by following steps in page-235 of UG586 https://www.xilinx.com/support/documentation/ip_documentation/mig_7series/v4_1/ug586_7Series_MIS.pdf
Deepika.
hi ,
i am using normal KC705 board.
does "init_calib_complete " low indicate a hardware issue?
please do reply. Thanks in advance.
Reshma
Did you try the step by step procedure as mentioned in below doc
https://www.xilinx.com/support/documentation/boards_and_kits/kc705/2014_3/xtp196-kc705-mig-c-2014-3.pdf
Do you see init_calib staying low with ready to download bit files provided with the MIG reference design from below link.
https://www.xilinx.com/products/boards-and-kits/ek-k7-kc705-g.html#documentation
Satish
