init_calib_complete at low
hi all,
i am posting this message to get a clarification for one reply in this thread.
https://forums.xilinx.com/t5/Memory-Interfaces/mig-core-in-ILA-is-invalid-init-calib-complete-low/m-p/734190#M10088
The issue with Mig core was that the reset pin was always high ( RTL miss )
Also the communication between DDR and pcie got established. The issue was that the inverted reset out of DDR has to be the reset input for the ddr. as soon as made this change in the RTL the DDR is up.
what is the meaning of this message?
MIG is having one reset input "sys_rst" and a reset output "ddr3_reset_n". Do i need to map this output to input?
is it the meaning of this message?
please do reply. I hope that it can solve all my problems related to MIG.
thanks in advance.
Reshma
Re: init_calib_complete at low
Sys_rst is input to the core and ddr3_reset_n is an output driven by the controller to the external DDR3 module and they shouldn't be looped back.
Sys_rst will have a polarity selection during the core generation and it should be driven by external hardware or internal logic based on the selected polarity.
Mig example design will have this generated correctly as per your selection and you can refer to it.
Satish
