Visitor 660471
using memory chip
Hi!
Is it possible to use memory chip MT41K128M16JT-125 IT instead MT41J128M16HA-15E IT of on
spartan xc6slx100tfgg484-3 ?
ddr_setting.jpgThe chip MT41J128M16HA-15E IT is in the list, but MT41K128M16JT-125 IT it is not.
Re: using memory chip
Hello @660471 ,
If the memory part is unavailable, please create a custom part. There is a description in the UG416. Please check these parameters between “MT41K128M16JT-125 IT ” and “MT41J128M16HA-15E IT ”.  If it’s the same, it is available. If it is not the same, please create a custom part.
http://www.xilinx.com/support/documentation/ip_documentation/mig/v3_92/ug416.pdf
kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
回复: using memory chip
I just you regenerate choose MT41K128M16XX-125 and regenereate the MIG IP.
