AXI Stream Switch inputs clocks
I want to use AXI-Stream switch IP to switch two different 'speed' Axi-Stream video data.  One of them is 148.5MHz, hdmi, the other one is my custom design Cameralink decoder which gives video data using Axi-Stream in 40MHz. Can I switch these two different clock speed Axi-Stream interface by using Axi-Stream Switch ? Should all Axi-stream slaves clock speed  be the same in Axi-Stream Switch? one more thing mean that 'aclk' port, for Slave Axi-stream interfaces or Master Axi-Stream interface ?
Re: AXI Stream Switch inputs clocks
Hello ,
Can I use Axi4-Stream Interconnect for switching two Axi-Stream interface via 'software' ?
